Ok, here is a pic of the KLX300R left engine case sitting in the 05 KX250F steel frame and attached by the swing arm pivot pin:
Here is another showing the back area of the case:
As you can see, the engine mounts will have to be completely redone.
That's not a big deal.
However, the area that is shown as the back of the left engine case has a frame brace that I believe will be in the way so it will have to be removed and re-located.
Still not a big deal if you can weld and cut tubing.
Here is a pic of the area where the cylinder and head will fit:
With the engine tilted up in front it's hard to say how much trimming and fitting will be required to make room for the head and head cover.
As a minimum I believe the head stay mount will need to be removed and re-located.
Again, not a big deal if you can weld.
Here is a pic showing the over all frame with the case in it:
Some of the things that aren't as obvious that I ran into with another conversion I am working on is the swing arm pivot pin bolt size is larger on the KX250F then the KLX300R engine. No biggie, you will need to drill the cases out a little larger.
The other thing that I can't check because I don't have the other engine side case is the swing arm width as respects to how wide the area is for the engine to sit inside of.
If you measure how wide the engine is where the swing arm goes, I will check the KX250F swing arm to see how wide it is.
I'm betting it is fairly close.
I had to grind a few thousands off my bushings on my project bike to make it work but it was very easy to do.
Another thing to look at is the air box boot, cdi mount, coil mount, radiator hose configuration, how the header will wrap around the frame, how to attach the exhaust arrestor or muffler, and kick start location to insure that it can clear all the frame components.
I'm probably missing a few other things but those are the ones that hit me on top of the head.
Generally speaking I think this is a viable conversion.
For those of you who ask why would you do this, not everyone want's the power and torque curve of a 250F or 450F engine.
Some people enjoy the torque of the 300R engine but want modern suspension so they can beat on the bike without worrying about the head tube which holds the triple clamps from popping off or bending their forks
Let us know what you come up with.
