KX GURU RACING HOW TO ACCURATELY MARK YOUR PISTON OILING HOLE LOCATIONS
All about your top end :-)
One of the things that you start to notice when building KX500's or any other 2t engine is that there are some area's you would like to see a bit more oiling.
Here is a well worn KX500 piston..
Notice the vertical lines in it...
Those are all places I would like to see some more oil..
KX GURU RACING HOW TO ACCURATELY MARK YOUR PISTON OILING HOLE LOCATIONS 101.jpg
KX GURU RACING HOW TO ACCURATELY MARK YOUR PISTON OILING HOLE LOCATIONS 101.jpg (365.09 KiB) Viewed 7974 times
Here is the area's on the cylinder that need a bit more oil..
But how can you accurately transfer that vertical location to the piston?
KX GURU RACING HOW TO ACCURATELY MARK YOUR PISTON OILING HOLE LOCATIONS 102.jpg
KX GURU RACING HOW TO ACCURATELY MARK YOUR PISTON OILING HOLE LOCATIONS 102.jpg (414.63 KiB) Viewed 7973 times
KX GURU RACING HOW TO ACCURATELY MARK YOUR PISTON OILING HOLE LOCATIONS 103.jpg
KX GURU RACING HOW TO ACCURATELY MARK YOUR PISTON OILING HOLE LOCATIONS 103.jpg (393.43 KiB) Viewed 7973 times
KX GURU RACING HOW TO ACCURATELY MARK YOUR PISTON OILING HOLE LOCATIONS 104.jpg
KX GURU RACING HOW TO ACCURATELY MARK YOUR PISTON OILING HOLE LOCATIONS 104.jpg (399.51 KiB) Viewed 7973 times
Re: KX GURU RACING HOW TO ACCURATELY MARK YOUR PISTON OILING HOLE LOCATIONS
Remember, you don't have a old worn out piston to work with that has the vertical lines drawn out for you :lol:
But the last thing you want to do is drill a hole in the wrong location and short circuit your engine :o :shock: :o
First things first, you need to mark to top of the piston with the location points you want to run vertical down your piston.
KX GURU RACING HOW TO ACCURATELY MARK YOUR PISTON OILING HOLE LOCATIONS 104.jpg (399.51 KiB) Viewed 7971 times
Next, pull the piston out of the cylinder and take a look.
KX GURU RACING HOW TO ACCURATELY MARK YOUR PISTON OILING HOLE LOCATIONS 105.jpg
KX GURU RACING HOW TO ACCURATELY MARK YOUR PISTON OILING HOLE LOCATIONS 105.jpg (422.26 KiB) Viewed 7970 times
KX GURU RACING HOW TO ACCURATELY MARK YOUR PISTON OILING HOLE LOCATIONS 106.jpg
KX GURU RACING HOW TO ACCURATELY MARK YOUR PISTON OILING HOLE LOCATIONS 106.jpg (367.87 KiB) Viewed 7970 times
Now for the hard part... Transferring the lines from the top of the piston to the sides...
You will need a "V" Block like this.
Here is the "V" block that I use..
I wish it was a little bigger but it works..
KX GURU RACING HOW TO ACCURATELY MARK YOUR PISTON OILING HOLE LOCATIONS 107.jpg
KX GURU RACING HOW TO ACCURATELY MARK YOUR PISTON OILING HOLE LOCATIONS 107.jpg (433.19 KiB) Viewed 7968 times
Put the piston into the "V" block and rotate the piston so that the mark on the top of the piston aligns with the edge of the block.
Once you have it aligned you can run a sharpie down it like so... Except.... IT won't work like this... :roll:
KX GURU RACING HOW TO ACCURATELY MARK YOUR PISTON OILING HOLE LOCATIONS 108.jpg
KX GURU RACING HOW TO ACCURATELY MARK YOUR PISTON OILING HOLE LOCATIONS 108.jpg (418.3 KiB) Viewed 7968 times
Now what???
Easy... Get a piece of material such as this piece of aluminum and raise the marker up a bit...
KX GURU RACING HOW TO ACCURATELY MARK YOUR PISTON OILING HOLE LOCATIONS 109.jpg
KX GURU RACING HOW TO ACCURATELY MARK YOUR PISTON OILING HOLE LOCATIONS 109.jpg (373.04 KiB) Viewed 7967 times
Now, run that marker down the edge and PRESTO!.... Oops...
KX GURU RACING HOW TO ACCURATELY MARK YOUR PISTON OILING HOLE LOCATIONS 110.jpg
KX GURU RACING HOW TO ACCURATELY MARK YOUR PISTON OILING HOLE LOCATIONS 110.jpg (317.79 KiB) Viewed 7967 times
Don't get in a hurry... If you mess up wipe the mark off and start over...
KX GURU RACING HOW TO ACCURATELY MARK YOUR PISTON OILING HOLE LOCATIONS 113.jpg
KX GURU RACING HOW TO ACCURATELY MARK YOUR PISTON OILING HOLE LOCATIONS 113.jpg (327.73 KiB) Viewed 7967 times
Sweeeeettttt 8-)
At this point you can mark your hole positions..
When you use the punch you don't need to wack it... Just a little tap will do ya..
KX GURU RACING HOW TO ACCURATELY MARK YOUR PISTON OILING HOLE LOCATIONS 115.jpg
KX GURU RACING HOW TO ACCURATELY MARK YOUR PISTON OILING HOLE LOCATIONS 115.jpg (502.04 KiB) Viewed 7965 times
I like leaving the piston in the "V" block because it holds the piston so nice.
Just be sure to air hose or wipe the piston and "V" block in between holes so you don't scratch up your nice new piston.. :oops:
KX GURU RACING HOW TO ACCURATELY MARK YOUR PISTON OILING HOLE LOCATIONS 117.jpg
KX GURU RACING HOW TO ACCURATELY MARK YOUR PISTON OILING HOLE LOCATIONS 117.jpg (376.1 KiB) Viewed 7965 times
I intentionally used a much larger drill bit then I needed because I wanted to accentuate any errors I might have made.
Once done I put the piston back into the cylinder and ran the piston up and down to see if I exposed any of the ports..
KX GURU RACING HOW TO ACCURATELY MARK YOUR PISTON OILING HOLE LOCATIONS 118.jpg
KX GURU RACING HOW TO ACCURATELY MARK YOUR PISTON OILING HOLE LOCATIONS 118.jpg (394.53 KiB) Viewed 7964 times
KX GURU RACING HOW TO ACCURATELY MARK YOUR PISTON OILING HOLE LOCATIONS 119.jpg
KX GURU RACING HOW TO ACCURATELY MARK YOUR PISTON OILING HOLE LOCATIONS 119.jpg (416.53 KiB) Viewed 7964 times
KX GURU RACING HOW TO ACCURATELY MARK YOUR PISTON OILING HOLE LOCATIONS 120.jpg
KX GURU RACING HOW TO ACCURATELY MARK YOUR PISTON OILING HOLE LOCATIONS 120.jpg (396.88 KiB) Viewed 7964 times
As you can see this was a perfect job.
Yes, sometimes I get lucky :lol:
Special tools? The "V" Block... sure... but they are not expensive...
http://www.ebay.com/sch/i.html?_from=R4 ... c&LH_BIN=1
Have fun :ugeek:
Drill hole size?
You can use many different sizes.
.080" is what I like but you can use a bit smaller or a bit bigger with no issues.
.120 is the large diameter of the counter sink that I use.
Again, it's not too critical but I would not go any bigger or you might short circuit your engine :lol:
Smaller is ok...
Counter sink included angle?
Whatever, it's not critical.
I use 60 degree, 90 degree, and whatever else I have laying around 8-)
Return to “Top End”
