How to remove a kick lever shaft from a XR350 & XR500
Bottom end tips and mods
Joe's guide on how to remove your kick lever shaft from your XR350 & XR500?
First remove your kick lever and clutch cover.
XR KICK LEVER SHAFT REMOVAL 1.JPG (50.79 KiB) Viewed 3696 times
Then, bolt your kick lever back on.
XR KICK LEVER SHAFT REMOVAL 2.JPG (48.45 KiB) Viewed 3696 times
Lay the engine on it's side..
XR KICK LEVER SHAFT REMOVAL 3.JPG (26.52 KiB) Viewed 3696 times
Re: How to remove your kick lever shaft from your XR350 & XR
Now, pull the lever all the way down... and tap upward on the bottom of the kick lever.
You don't have to tap very hard.
XR KICK LEVER SHAFT REMOVAL 4.JPG (64.91 KiB) Viewed 3695 times
The kick lever shaft will pop out but you will have to move it around a bit to get it out.
XR KICK LEVER SHAFT REMOVAL 5.JPG (34.89 KiB) Viewed 3695 times
Return to “Bottom end”
