Hello.
Your cylinder should have 1911 embossed on the left side of the cylinder back by where the reed cage is.
If it is embossed with 1911 then it only FITS 00 KX250 P/N 11005-1911
BORE 67.40 STROKE 72MM
If there is any other number there, let me know what it is and I will tell you what year it is and what other years it will fit.
The book shows that only 2000 KX250 engine cases will work for your needs.
Unfortunately we don't have the cases or cylinders left for that year.
All our 2000 KX250 parts are here:
http://stores.ebay.com/OEM-CYCLE/_i.htm ... c=1&_sop=1
Remember, if you need something don't order on eBay, just let us know what you need and we will get you direct pricing.
Out of curiosity, what is wrong with your existing cylinder?
