JT Engine Works 1989 RM250 engine build
I'm a bit late in all of this...
So this is a quick recap.
Disassembled, Vapor blasted, lapped, and vapor blasted again engine cases.
All new bearings, seals, gaskets, o-rings, washers, bushings, snap rings, alignment pins, ect.
The crank is balanced, polished rod, trued, welded.
The cylinder is plated but left at stock bore with stock port timing.
It does have some scuff n buff to clean up the factory casting flaws..
JT ENGINE WORKS 1989 RM250 ENGINE BUILD 101.JPG (181.99 KiB) Viewed 6990 times
JT ENGINE WORKS 1989 RM250 ENGINE BUILD 102.JPG (163.21 KiB) Viewed 6990 times
Re: JT Engine Works 1989 RM250 engine build
JT ENGINE WORKS 1989 RM250 ENGINE BUILD 103.JPG (256.17 KiB) Viewed 6989 times
JT ENGINE WORKS 1989 RM250 ENGINE BUILD 104.JPG (192.73 KiB) Viewed 6989 times
JT ENGINE WORKS 1989 RM250 ENGINE BUILD 105.JPG (187.91 KiB) Viewed 6988 times
JT ENGINE WORKS 1989 RM250 ENGINE BUILD 106.JPG (181.46 KiB) Viewed 6988 times
JT ENGINE WORKS 1989 RM250 ENGINE BUILD 107.JPG (193.08 KiB) Viewed 6987 times
JT ENGINE WORKS 1989 RM250 ENGINE BUILD 108.JPG (170.7 KiB) Viewed 6987 times
JT ENGINE WORKS 1989 RM250 ENGINE BUILD 109.JPG (177.19 KiB) Viewed 6987 times
Jason is so fussy it's crazy... But good crazy... More tomorrow...
Jason made some more progress today..
JT ENGINE WORKS 1989 RM250 ENGINE BUILD 110.JPG (132.57 KiB) Viewed 6982 times
JT ENGINE WORKS 1989 RM250 ENGINE BUILD 111.JPG (164.67 KiB) Viewed 6982 times
JT ENGINE WORKS 1989 RM250 ENGINE BUILD 112.JPG (152.55 KiB) Viewed 6982 times
It's really turning out nice...
More progress tonight
JT ENGINE WORKS 1989 RM250 ENGINE BUILD 113.JPG (196.93 KiB) Viewed 6978 times
JT ENGINE WORKS 1989 RM250 ENGINE BUILD 114.JPG (246.17 KiB) Viewed 6978 times
JT ENGINE WORKS 1989 RM250 ENGINE BUILD 115.JPG (236.07 KiB) Viewed 6978 times
JT ENGINE WORKS 1989 RM250 ENGINE BUILD 116.JPG (165.22 KiB) Viewed 6977 times
JT ENGINE WORKS 1989 RM250 ENGINE BUILD 117.JPG (169.81 KiB) Viewed 6977 times
JT ENGINE WORKS 1989 RM250 ENGINE BUILD 118.JPG (173.43 KiB) Viewed 6976 times
JT ENGINE WORKS 1989 RM250 ENGINE BUILD 119.JPG (188.54 KiB) Viewed 6976 times
Should have it ready to ship tomorrow... :shock:
