1975 kx400 rear hub
Caferacer78
1975 kx400 rear hub
Having great difficulty finding 1975 kx400 rear hub.Oem cycle interchange says my 81 kdx2 250 hub will work but the backing plate is not even close. Anyone know of a backing plate that will work? I would use any hub combination just to finish this bike. Original parts are scarce, so are the kx250 hubs that interchange. Thanks for any help with this.
Re: 1975 kx400 rear hub
According to Kawasaki part numbers 42005-045-21 the following hubs will work.
1974 KX250 REAR HUB-BRAKE-CHAIN (KX250-A-A3)
1975 KX250-A REAR HUB-BRAKE-CHAIN (KX250-A-A3)
1975 KX400 REAR HUB-BRAKE-CHAIN
1976 KX250-A3 REAR HUB-BRAKE-CHAIN (KX250-A-A3)
1976 KX400-A2 REAR HUB-BRAKE-CHAIN
1978 KX250-A4 REAR HUB-BRAKE-CHAIN (KX250-A-A3)
1979 KX250-A5 REAR HUB-BRAKE-CHAIN (KX250-A-A3)
The info on the interchange page is out of date and not accurate.
I will be updating it later today.
On the rear brake backing plate 42006-059 here is the current interchange
More on this in a bit
Ok, the interchange pages have been updated to the latest info I have available.
