Gotta have 2.....
Posted: Fri Apr 29, 2016 1:20 pm
Seems like finding a good crank case for a k5 is getting harder and harder. Ive bought matched cases with spun journals and unmatched cases alike. Being told they are good just to receive them and find otherwise. Tried a couple things with the main journals to find that the only epoxy that WILL serve as a long term fix is a brand cAlled Belzona. Product # 1511. It's not cheap either. $360 bucks for a 1 kg /2 component kit. But once hardened it withstands local temperatures up to 350 degrees F. Plus it handles the chemical attack the oils and any gas escaping from the combustion chamber may hit it with. The other options I've found to be worthy of holding the bearing tight are sleeving the journal with a piece of pipe lathed to the diameter both I/d and0/d needed. But finding the lathe to do the job is the tough find there. And finally hard chroming the main journals back to the correct specs for the crank bearings is another option. The least expensive I've found is $500 bucks a journal . So there's that. I'm sure there's other not so permanent options . Like peen ing the bearing in the journal or welding it in. Jb weld last about a week before it breaks down . But finally I did find 2 sets of cases that are still in good/ damn good shape. The only thing is I gotta have 2 k5's due to the fact if I only have one I'll beat the piss out of it and end up with one more wasted case.
