54739005000 FP8172 FLYWHEEL ROTOR PICS MEASUREMENTS INTERCHANGE
Posted: Mon Oct 26, 2015 6:15 pm
2000 KTM 250 SX FLYWHEEL ROTOR MEASUREMENTS AND PICS
Part number: 54739005000
This interchange info is according to www.munnracing.com
FP8172
2000 KTM 250 SX FLYWHEEL ROTOR MEASUREMENTS AND PICS.JPG (126.27 KiB) Viewed 8614 times
1997 125 SIX DAY LE IGNITION KOKUSAN 2K-1/2K2/2k3 `98 (Item Number 1)
1997 200 EXC JACKPINER IGNITION KOKUSAN 2K-1/2K2/2k3 `98 (Item Number 1)
1997 250 EXC M/Ö 13LT IGNITION KOKUSAN 2K-1/2K2 (Item Number 1)
1997 250 SX M/Ö IGNITION KOKUSAN 2K-1/2K2 (Item Number 1)
1997 300 EXC M/Ö 13lt IGNITION KOKUSAN 2K-1/2K2 (Item Number 1)
1997 300 MXC M/Ö 13lt IGNITION KOKUSAN 2K-1/2K2 (Item Number 1)
1997 360 EXC M/Ö 13lt IGNITION KOKUSAN 2K-1/2K2 (Item Number 1)
1997 360 MXC M/Ö 13lt IGNITION KOKUSAN 2K-1/2K2 (Item Number 1)
1997 360 SX M/Ö IGNITION KOKUSAN 2K-1/2K2 (Item Number 1)
1998 125 EGS 6KW (D) IGNITION KOKUSAN 2K-1/2K2/2k3 `98 (Item Number 1)
1998 125 EXC IGNITION KOKUSAN 2K-1/2K2/2k3 `98 (Item Number 1)
1998 125 SX IGNITION KOKUSAN 2K-1/2K2/2k3 `98 (Item Number 1)
1998 200 EXC IGNITION KOKUSAN 2K-1/2K2/2k3 `98 (Item Number 1)
1998 200 MXC IGNITION KOKUSAN 2K-1/2K2/2k3 `98 (Item Number 1)
1998 250 EXC 12lt IGNITION KOKUSAN 2K-1/2K2 `98 (Item Number 1)
1998 250 MXC IGNITION KOKUSAN 2K-1/2K2 `98 (Item Number 1)
1998 250 SX IGNITION KOKUSAN 2K-1/2K2 `98 (Item Number 1)
1998 300 EXC 12lt IGNITION KOKUSAN 2K-1/2K2 `98 (Item Number 1)
1998 300 MXC 12lt IGNITION KOKUSAN 2K-1/2K2 `98 (Item Number 1)
1998 380 EXC 12lt IGNITION KOKUSAN 2K-1/2K2 `98 (Item Number 1)
1998 380 MXC 12lt IGNITION KOKUSAN 2K-1/2K2 `98 (Item Number 1)
1998 380 SX IGNITION KOKUSAN 2K-1/2K2 `98 (Item Number 1)
1999 125 EGS 6KW (D) IGNITION KOKUSAN 2K-1/2K2/2k3 `99 (Item Number 1)
1999 125 EXC IGNITION KOKUSAN 2K-1/2K2/2k3 `99 (Item Number 1)
1999 125 SX IGNITION KOKUSAN 2K-1/2K2/2k3 `99 (Item Number 1)
1999 200 EXC IGNITION KOKUSAN 2K-1/2K2/2k3 `99 (Item Number 1)
1999 200 MXC IGNITION KOKUSAN 2K-1/2K2/2k3 `99 (Item Number 1)
1999 250 EXC 12lt IGNITION KOKUSAN 2K-1/2K2 (Item Number 1)
1999 250 MXC IGNITION KOKUSAN 2K-1/2K2 (Item Number 1)
1999 250 SX IGNITION KOKUSAN 2K-1/2K2 (Item Number 1)
1999 300 EXC 12lt IGNITION KOKUSAN 2K-1/2K2 (Item Number 1)
1999 300 MXC 12lt IGNITION KOKUSAN 2K-1/2K2 (Item Number 1)
1999 380 EXC 12lt IGNITION KOKUSAN 2K-1/2K2 (Item Number 1)
1999 380 MXC 12lt IGNITION KOKUSAN 2K-1/2K2 (Item Number 1)
1999 380 SX IGNITION KOKUSAN 2K-1/2K2 (Item Number 1)
2000 125 EXC IGNITION KOKUSAN 2K-1/2K2/2k3 `2000 (Item Number 1)
2000 125 SX IGNITION KOKUSAN 2K-1/2K2/2k3 `2000 (Item Number 1)
2000 125 SXS (A) IGNITION KOKUSAN 2K-1/2K2/2K3 `2000 (Item Number 1)
2000 200 EXC IGNITION KOKUSAN 2K-1/2K2/2k3 `2000 (Item Number 1)
2000 200 MXC IGNITION KOKUSAN 2K-1/2K2/2k3 `2000 (Item Number 1)
2000 250 EXC IGNITION KOKUSAN 2K-1/2K2/2K3 `2000 (Item Number 1)
2000 250 MXC IGNITION KOKUSAN 2K-1/2K2/2K3 `2000 (Item Number 1)
2000 250 SX IGNITION KOKUSAN 2K4 `2000 (Item Number 1)
2000 300 EXC IGNITION KOKUSAN 2K-1/2K2/2K3 `2000 (Item Number 1)
2000 300 MXC IGNITION KOKUSAN 2K-1/2K2/2K3 `2000 (Item Number 1)
2000 380 EXC IGNITION KOKUSAN 2K-1/2K2/2K3 `2000 (Item Number 1)
2000 380 MXC IGNITION KOKUSAN 2K-1/2K2/2K3 `2000 (Item Number 1)
2000 380 SX IGNITION KOKUSAN 2K-1/2K2/2K3 `2000 (Item Number 1)
2001 125 SX IGNITION KOKUSAN 2K-1/2K-2/2K-3 2001 (Item Number 1)
2001 125 SXS IGNITION KOKUSAN 2K-1/2K-2/2K-3 2001 (Item Number 1)
2001 250 SX IGNITION KOKUSAN 2K4 2001 (Item Number 1)
2001 250 SXS IGNITION KOKUSAN 2K4 2001 (Item Number 1)
2002 125 SX IGNITION KOKUSAN 2K-1/2K-2/2K-3 2001 (Item Number 1)
2002 125 SXS IGNITION KOKUSAN 2K-1/2K-2/2K-3 2001 (Item Number 1)
2002 250 SX IGNITION KOKUSAN 2K-1/2K-2/2K-3 2002 (Item Number 1)
2002 250 SX VORSERIE MOD.03 IGNITION SYSTEM KOKUSAN 2K-1 250 SX (Item Number 5)
2003 125 SX IGNITION SYSTEM KOKUSAN 2K-1/2K-2/2K-3 (Item Number 1)
2003 125 SXS IGNITION SYSTEM KOKUSAN 2K-1/2K-2/2K-3 (Item Number 1)
2003 250 SX IGNITION SYSTEM KOKUSAN 2K-1 250 SX (Item Number 5)
2003 250 SXS IGNITION SYSTEM KOKUSAN 2K-1 250 SX (Item Number 5)
2004 125 SX IGNITION SYSTEM KOKUSAN 2K-1/2K-2/2K-3 (Item Number 1)
2004 125 SXS IGNITION SYSTEM KOKUSAN 2K-1/2K-2/2K-3 (Item Number 1)
2004 250 SX IGNITION SYSTEM KOKUSAN 2K-1/2K-2/2K-3 (Item Number 1)
2004 250 SXS IGNITION SYSTEM KOKUSAN 2K-1/2K-2/2K-3 (Item Number 1)
2005 125 SX Ignition system Kokusan 2K--1 125 SX (Item Number 1)
2005 125 SX TYLA RATTRAY Ignition system Kokusan 2K--1 125 SX (Item Number 1)
2005 125 SXS Ignition system Kokusan 2K--1 125 SX (Item Number 1)
2005 250 SX Ignition system Kokusan 2K--1 125 SX (Item Number 1)
2005 250 SXS Ignition system Kokusan 2K--1 125 SX (Item Number 1)
2006 125 SX IGNITION SYSTEM (Item Number 2)
2006 125 SXS IGNITION SYSTEM (Item Number 2)
2006 250 SX IGNITION SYSTEM (Item Number 2)
2007 125 SX IGNITION SYSTEM (Item Number 2)
2007 125 SXS IGNITION SYSTEM (Item Number 2)
2007 144 SX IGNITION SYSTEM (Item Number 2)
2008 125 SX IGNITION SYSTEM (Item Number 2)
2008 144 SX IGNITION SYSTEM (Item Number 2)
