CRANKCASE BOLT PLACEMENT TORQUE SPECS PICS
Both bolts have the same specs
Torque Specs:
60 inch lb or 5 ft lb
6.9 NM
Basically there are four of the M6 x 1.0 x 50mm bolts represented with the red circles.
And eight of the M6 x 1.0 x 60mm bolts represented with the blue circles.
132BA0650 BOLT-FLANGED-SMALL MEASUREMENTS PICS SPECS
viewtopic.php?f=49&t=1066
132BA0660 132A BOLT-FLANGED-SMALL MEASUREMENTS PICS SPECS
viewtopic.php?f=49&t=1067
KX500 ENGINE CASE BOLT PLACEMENT PICS AND MEASUREMENTS 102.JPG (120.62 KiB) Viewed 16917 times
