How hot is too hot for your bearings, cases, and seals?
Posted: Thu Apr 16, 2015 7:11 am
We are experimenting and should have some results fairly soon... :shock:
Re: How hot is too hot for your bearings, cases, and seals?
Posted: Fri Apr 17, 2015 11:44 pm
by 81cr450
I have an aluminum hardness tester at work if it helps any, also have a sacrificial case set. I don't think you could get bearings hot enough to ...
Posted: Sat Apr 18, 2015 2:13 am
Ah.... fantastic.
I can even send you some cases if necessary...
I've head but never had it proved that at 400F aluminum starts having issues...
It would be cool to prove it...
And heating bearings as a whole would take a lot of heat to ruin a bearing..... However...... Using the Motorrad method could damage a bearing if you over heat. I found a new KX500 bearing and will ruin it next week and show my results :lol:
Posted: Sat Apr 18, 2015 3:02 am
by 81cr450
I'm thinking, heat a case half in the oven to 300 test, 350 test , 400 test. I'm betting its done there but if Im wrong, could keep going. The tester is aerospace quality, we use it to test for junk d-max heads. This is awesomeness , most screwed up parts are from the "mechanic" , nice to learn the actual failure point. Got a junk AF frame , I'd like to learn more about frame anealing too
Posted: Mon May 18, 2015 10:05 pm
Here is some results for welding on Aluminum frames:
These results were based on the Brinell scale.
Here is the test piece from a 01 CR250:
test piece 1.JPG (71.22 KiB) Viewed 9097 times
01 CR250 square tube stock is 74
The edge of the weld is 70
The weld is 70.
Here's some comparison specs
86 CR500 swing arm 82
87 KX500 swing arm 78
97 KX500 swing arm 72 seemed odd but got the same # in multiple spots
2003 CR250 swing arm 83 , the frame is 80-83.
Posted: Mon May 18, 2015 10:06 pm
The person who did the testing said that he see's failures at about 60 on the Brinell scale.
