Posted: Sat Feb 21, 2015 11:04 am
Right, the subframe needs a lot of work yet, plenum to finish, piping from turbo to plenum, a tray of some kind for the electrics, plumbing for the W/M set up aaand the W/M tank, which is where I thought I would start. I've been making bits up when I've had a chance over the last few weeks, little bosses and caps and screws for attaching all the plastics to the back of the bike. I had previously made up this jig which helped with getting some of the bits in the right place.
Now I've been busy with work recently, and this last week I thought, right, a day off for the KLX, and when I got going I was just cracking on, kind forgot all about the photos till it was done, oops. What happened was...... I folded a bottom for the tank, welded it in, put on the back of the tank, a square, trimmed to size once on (the easy way, I'm no pro, ha!) put in a little flat bit at the back at the appropriate height to mount the attachment points for the rear plastics and the number plate, stoplight, etc.then a plate upstanding again to fill the space fully under the rear mudgaurd, then folded a top. I had found a vented filler neck on eBay , which was sitting around waiting for this job to be done.
There it is, just a outlet boss to be welded in and a boss for a vent pipe.
And with it's clothes on.....
It was good to get this job done, another milestone!
