It's better but I have some new polishing compounds to try so I think it will even be better when I'm done..
Frank The Tank
Post by Frank The Tank »
I don't see much happenin with this bike.
Your probably busy with the weather and all gettin better.
Actually I am still working on this bike :shock:
I'm making a 2 piece clutch cover for it.
So I'll update the thread when I get the cover done and start building the engine.
Yep, that is a real work of art.
I can't wait to get mine done..
Update:
The crank is done and on it's way back.
The cylinder should be done and should be back soon as well.
Hopefully I can start building the bottom end within the week..
Received the crank back from Pinsonnault Racing.
Impressive does not do them justice.
Check out my review here:
viewtopic.php?f=39&t=357
Can you guess what this is?
KX500 SCOTTS STEERING STABILIZER 1.JPG (58.38 KiB) Viewed 13629 times
Nope, not the grease :D
Post by Motorrad »
Kinda makes it easy to guess when you have the picture file named...
that and there is one on several of my bikes.. so it makes it easy to spot.
You think I made it too easy ? :D
Post by Motorrad »
Sandblaster wrote:You think I made it too easy ? :D
Umm yes
I expected a challenge...
