KX500 2 piece clutch cover adapter
Post by Motorrad »
Your 2x4 is dirty. You really should take better care of your stuff. :roll:
You haven't seen the half of it :-)
I finally spent some time on this project today.
I made another version to keep the cost as low as possible.
I think 5 profiles and all the holes can be machined in one set up, then the last step would have to be done one at a time unless a jig was made.
But for now, no jig..
I'm getting quotes on the material and the machining.
I hope to have some news fairly soon.
After a few of us verify the design viability then I will let every one know the cost.
Then, I will look at making custom covers and a slightly different design :-o
The material is here and I have two quotes coming for the machine work.....
I've sent the prints to 5 companies and no response...
I'm tired of waiting..
KX500 2 PIECE CLUTCH COVER 1.JPG (55.96 KiB) Viewed 22779 times
Here's some more styles.
kx500 2 piece clutch cover 1.png (1023.42 KiB) Viewed 22775 times
kx500 2 piece clutch cover 2.png (329.12 KiB) Viewed 22775 times
kx500 2 piece clutch cover 3.png (622.21 KiB) Viewed 22775 times
kx500 2 piece clutch cover 4.png (645.05 KiB) Viewed 22775 times
kx500 2 piece clutch cover 5.png (476.08 KiB) Viewed 22775 times
kx500 2 piece clutch cover 6.png (292.16 KiB) Viewed 22775 times
kx500 2 piece clutch cover 7.png (506.54 KiB) Viewed 22775 times
kx500 2 piece clutch cover 8.png (343.73 KiB) Viewed 22775 times
kx500 2 piece clutch cover 9.png (411.31 KiB) Viewed 22775 times
kx500 2 piece clutch cover 9-3.png (2.5 MiB) Viewed 22775 times
kx500 2 piece clutch cover 9-4.png (365.81 KiB) Viewed 22775 times
Return to “Clutch”
