Ok.. The case is back from weld and the cylinder has the valves installed so I can cut the sub port outlets to match the valves...
Still waiting on parts.....
Kx500fan
Post by Kx500fan »
Any updates?
Yeah... Still waiting for the stinkin gears :x
However, the crank should be here very soon 8-)
Finally.. the crank is here :shock:
Incidentally... Send your crank parts out for assembly and balancing while dirty... and they will come back dirty with a new rod kit.
Send them out clean or polished and the results speak for themselves.
KX GURU RACING 1992 KX500 SNOW BIKE ENGINE BUILD FOR BRENT 145.JPG (243.01 KiB) Viewed 10802 times
I'll be calling on Tuesday to get an update on the gears...
Jason spent a couple of hours today cleaning up the left case weld for the counter sprocket guard.
Turned out really nice.
He also enlarged the main bearing oiling hole and capture point.
Also, he spent some time cleaning up the chain wear around the output shaft.
KX GURU RACING 1992 KX500 SNOW BIKE ENGINE BUILD FOR BRENT 146.JPG (380.6 KiB) Viewed 10788 times
KX GURU RACING 1992 KX500 SNOW BIKE ENGINE BUILD FOR BRENT 147.JPG (361.21 KiB) Viewed 10788 times
KX GURU RACING 1992 KX500 SNOW BIKE ENGINE BUILD FOR BRENT 148.JPG (353.02 KiB) Viewed 10788 times
A bit more progress...
KX GURU RACING 1992 KX500 SNOW BIKE ENGINE BUILD FOR BRENT 149.JPG (421.78 KiB) Viewed 10754 times
Bearings and seals are in...
KX GURU RACING 1992 KX500 SNOW BIKE ENGINE BUILD FOR BRENT 150.JPG (431.14 KiB) Viewed 10754 times
Gettin it ready..
KX GURU RACING 1992 KX500 SNOW BIKE ENGINE BUILD FOR BRENT 151.JPG (444.74 KiB) Viewed 10753 times
Crank is in...
KX GURU RACING 1992 KX500 SNOW BIKE ENGINE BUILD FOR BRENT 152.JPG (455.38 KiB) Viewed 10753 times
Even though we are not ready to install the trans and such we still need some additional info before we send the cylinder and head out for work :shock:
Ready for the cases to be assembled.
KX GURU RACING 1992 KX500 SNOW BIKE ENGINE BUILD FOR BRENT 153.JPG (503.6 KiB) Viewed 10720 times
Case halves are assembled..
KX GURU RACING 1992 KX500 SNOW BIKE ENGINE BUILD FOR BRENT 154.JPG (313.76 KiB) Viewed 10720 times
