I'm on information overload
I'm trying to figure a safe rev limit.
If your running the Wossner rod it can safely run up more RPM's then the stocker.
Max Power 39.39 hp @ 6500 rpm
Bore x Stroke 100 x 83mm
So, 6500 is where max power is at, but of course, you can make power after that just decreasingly so.
7500 is where the stock rev limit is at.
Therefore 7500 is safe.
Are you going to balance your crank/piston assembly?
If so, what balance factor are you going to use?
A well balanced motor can safely rev higher.-
With the Wossner rod I would think that you could easily and safely run 8500-9000 rpm
By contrast my KX500 has a 86mm stroke and runs at 8500 rpm stock.
With some port work and balancing they will wick up to 10,500+ rpm.
I'm not saying it's safe, just that it will
Since you have a dyno and the programmable CDI why not start off low and see how it sounds and feels?
If the power is smoothly increasing right up to the rev limit and it feels good then bump it up.
Just taking a wild guess here, I bet you will end up in the 9500 to 10,000 rpm range.
Safely? I guess we will see
Oh... and you may have to increase the spring rate on those valves to keep them from floating at those RPM's
More later after I absorb all this...
