I worked a bit today making a new muffler.
I took a FMF Power Core and shortened it 5.5" :shock:
In Oregon we can get a sound ticket for being too loud in the woods, sand dunes or any other state ran riding area.
On the street, you can run whatever.
Makes perfect sense to me :?:
Here is what I started with:
First step was disassembly.
Whoever owned this before replaced the packing and sealed both ends with silicone.
I would not recommend using silicone to seal your muffler ends if you ever plan on packing the muffler again as it was very difficult to get it apart.
Since I was cutting mine anyway it wasn't as big of a deal.
With the muffler cut I removed both end and the packing material.
With all the material removed I cut the inner perforated tube to the correct length.
Then I drilled the new end cap holes.
New packing material....
Assembled it.
It took about an hour to do this because I had to go next door to a machine shop and borrow a water cooled band saw to cut the muffler in half.....
Sometimes it adds to your build time because you need to say hi to everyone, answer all their questions ect...
Still I am very happy with how this turned out.
Next, I am thinking about beveling the bottom....
So stay tuned....
OK, I couldn't leave well enough alone.
After marking out my cut lines I decided to start cutting :lol:
KX500 SM MUFFLER MOD1
KX500 SM MUFFLER MOD1.JPG (82.4 KiB) Viewed 17398 times
KX500 SM MUFFLER MOD2
KX500 SM MUFFLER MOD2.JPG (85.2 KiB) Viewed 17398 times
KX500 SM MUFFLER MOD3
KX500 SM MUFFLER MOD3.JPG (93.56 KiB) Viewed 17398 times
A few more tweaks and a trip to the weld shop and I'll have something a little different.
I also ordered some square tubing for the outlet....
KX500 SM MUFFLER MOD4.JPG (15.11 KiB) Viewed 17398 times
KX500 SM MUFFLER MOD5.JPG (11.82 KiB) Viewed 17398 times
More to come...
Here is the project after first stage welding.
KX500 SM MUFFLER MOD6.JPG (77.93 KiB) Viewed 17397 times
KX500 SM MUFFLER MOD7.JPG (78.08 KiB) Viewed 17397 times
More to come after I get my square tubing...
And then I started thinking about.....
KX500 SM MUFFLER MOD8.JPG (12.54 KiB) Viewed 17395 times
Here's where I am at tonight.
KX500 SM MUFFLER MOD8-1.JPG (162.64 KiB) Viewed 17394 times
KX500 SM MUFFLER MOD8-2.JPG (49.08 KiB) Viewed 17394 times
Now I'm waiting for the aluminum tubing to come in.
Or, perhaps I'll do something like this:
k5sm muffler.JPG (42.4 KiB) Viewed 17384 times
I was asked how I was going to make the internal baffling.
This is a rough idea.
I am tying the two pieces of internal baffling with some small pieces of plate not shown in the pics.
The lower tube will be functional but the upper tube will take the major volume of exhaust.
k5sm muffler baffel.JPG (95.38 KiB) Viewed 17372 times
Even though this will be primarily for street use I am installing some stainless steel mesh for a spark arrestor.
KX500 SM MUFFLER MOD ARRESTOR.JPG (29.29 KiB) Viewed 17372 times
The aluminum tubing arrived today so I cut it in half at the approximate finish angle and took the pieces to have them tig welded.
KX500 SM MUFFLER MOD8-3.JPG (89.29 KiB) Viewed 17366 times
KX500 SM MUFFLER MOD8-4.JPG (92.44 KiB) Viewed 17366 times
Once the pieces are tigged together I will finish shaping them and then have them tigged to the muffler body.
Steve O
Post by Steve O »
Now your just teasing us!
Steve O wrote:Now your just teasing us!
That's not teasing, this is :D
KX500 SM MUFFLER MOD8-5.JPG (59.32 KiB) Viewed 16763 times
