Right, a while there with not much done, phisically anyway but some parts gathering and planning, lots of planning, most discarded for being daft/crazy/impossible.
I took a cylinder head, cylinder and piston to work with me to familiarise myself with the parts.
I got a bit tempted to do a big bore, that was the main reason for the hours of fondeling those castings, but Iv kind of gone off the idea, the extra time and effort and then the extra gas to go past the valves and that goes especially in the case of the exhaust valve. There will be a bit of heat there just dealing with 651cc. I already have a 100mm standard bore wossner piston as well. So, standard bore it is.
My bench is abit of a disgrace, tools and aluminium dust from the plenum build, I cleared it up a bit but I had already decided a new bench was needed, one dedicated to spanners bolts and stuff. No welding and grinding allowed. So a few bits of wood, screws and a big bottle of glue.
It might be a bit high but I always end up face into everything peering at it so the height might be ok? If you cared to look closely at it, it would betray my lack of carpentry skill but I do not expect it to fold in a hurry. It's braced in all panes by plywood and that's a 2" top, bench sorted.
So, let's get some use out of it. Here's some of the new internals, I was going to run the engine as made but the standard cast piston really would not do with the extra heat. So to solve that a forged wossner piston has been sourced, I got it about a year ago, off eBay, it's brand new but 2nd hand.
The other parts here are head and base gaskets and a full gasket set(not in pic) a new crank pin and thrust washers, a Carrillo rod, a KLX "R" inlet cam and a walkers of NZ clutch with uprated springs. Another thing I forgot to dig out for the picture is a set of viton valve stem seals.
There is also a new carb/air box adaptor there, I found it on eBay, it came from a vendor in Holland it is a more satisfactory adaptor with more sealing area than the one I had before, better for handling some pressure, hopefully.
And most obviously yet another engine. The engine is still in the bike, I got another one around Christmas and then another last week. I am sure I will wreck one do another is handy.
The last bit of this update is slightly off topic but same kind of vein, I found this little gem, again on eBay, a KR1-S 250........
The plan is to take out the little two stroke engine and shoehorn a KLX engine in it. Only after I get the turbo supermoto up and running. It's been set up for racing so there is an uprated shock and zxr400 usd forks so it's a decent base to start from.
The next move is to strip down one of those engines on the bench, to get the crank out, I'm going to order a new set of rollers for the big end, I mistakenly thought that a bearing came with the rod but I misread the email on that one,
, no matter. I am going to take the crank to a specialist crank builder, to fit the rod, bearing and to weld it up to help it cope.
Then after I get the last of the intake made up I will take the engine out of the bike and strip that bike down and build it up with the assembled trick parts.
So lots to do, as usual.
