Ok... Finally, it's ready for some touch up welds, then off to sandblast, and finally Powder coat..
Unimpressive to say the least but it's a big step forward..
It's time to start working on the rear brake caliper..
Here is what I am starting with..
The goal is to get rid of all the casting flaws, markings, logos, ect.
Not completely done... but you can get the idea..
kx guru ktx500e 101.jpg (258.57 KiB) Viewed 10702 times
kx guru ktx500e 102.jpg (350.38 KiB) Viewed 10702 times
kx guru ktx500e 103.jpg (229.08 KiB) Viewed 10702 times
kx guru ktx500e 104.jpg (361.21 KiB) Viewed 10702 times
Back from Powder coating.. :shock: :o 8-)
KX GURU RACING POWDER COATING THE FRAME KTX500E 101.jpg (307.89 KiB) Viewed 10694 times
KX GURU RACING POWDER COATING THE FRAME KTX500E 102.jpg (312.3 KiB) Viewed 10694 times
Upper mounts are done..
KX GURU RACING UPPER ENGINE MOUNTS KTX500E 103.jpg (396.1 KiB) Viewed 10693 times
This cylinder was beat...bad...
It was sleeved and whoever did it had the sleeve badly misaligned not only vertically but also on the radius :shock:
Because it was in such bad condition and I really don't like sleeves I never thought I would be using it.
But, I have some test I want to do and if I jack this cylinder up I don't really care...
Ok... I do care but not as much as some of the nicer cylinder I have 8-)
Before..
KX GURU RACING KX500 CYLINDER 101.jpg (292.33 KiB) Viewed 10662 times
Before we sent it out to have it bored and decked we did a rough bore and then did some preliminary port work.
Then we sent it to Tom Morgan Racing to have it final bored and decked...
Tom does very nice work.
I have not checked the bore yet but I'm sure it will mic out perfectly... or close enough for this cylinder :lol:
After
KX GURU RACING KX500 CYLINDER 102.jpg (261.8 KiB) Viewed 10662 times
I think a little Cerakote Clear on this will keep it looking fresh for at least a few days :lol:
KX GURU RACING KTX500E LINKAGE 101.jpg (372.7 KiB) Viewed 10652 times
Jason the hand model is holding the wheel :lol:
KX GURU RACING WHEELS 101.jpg (486.74 KiB) Viewed 10636 times
KX GURU RACING WHEELS 102.jpg (465.63 KiB) Viewed 10636 times
KX GURU RACING WHEELS 103.jpg (450.9 KiB) Viewed 10636 times
Leo Sadzewicz sent me a little something in the mail... Can you guess what? That should help keep things clean and tidy :-)
ktx500e kx guru racing 108.jpg (315.2 KiB) Viewed 10605 times
If anyone is interested in a cool oil filler for your KX500 here is Leo's contact info:
575-621-5171
neverfrankie@gmail.com
TM DESIGNWORKS does really nice work.
Thanks guys!
KX GURU RACING - TM DESIGNWORKS KXT500E 102.jpg (650.01 KiB) Viewed 10597 times
KX GURU RACING - TM DESIGNWORKS KXT500E 101.jpg (577.96 KiB) Viewed 10597 times
