60something
Post by 60something »
I was looking at the ORV laws for Michigan state ORV trails and here is the noise standard (besides requiring a spark arrestor):
"Exhaust noise must not exceed 99 dB(A)—or 94 dB(A) on
vehicles manufactured after January 1, 1986—when tested
according to the provisions of the SAE J1287 test." :shock:
Never gave it a second thought on the KDXs, but I'm a bit concerned about the K5.
1987 Kawasaki KX500
We have noise and arrestor laws here in Oregon.
I have never had a issue as the KX500 has a lower tone then smaller bikes.
Guys get pulled over left and right to be tested and I ride by in a high gear and low throttle.
I've only gotten one look as I went by but I think it is because my bike looks so good :lol:
BigTerry
Post by BigTerry »
Couldn't help but notice a lack of updates on this way cool build. For a month. Here and on Vital. MXA issue a cease & desist ? I get it I guess, if so Mike. Could we get a sneek peek please ?
Lol... No, nothing like that.
I'm waiting for some parts so I can move forward.
I've been designing, redesigning, welding, machining, rewelding, remachining, ect the Guru valves.
Turns out they were a bit more difficult then I intended.
But I have made significant progress on them and I believe after I pick them up this week I can hand work the final machine work and test them out.
Before I install them in my KTX I will be testing them in my Sand bike to be sure they operate as intended and with some reliability.
Once proven I will take the top end off and swap it into the KTX.
As soon as the pipe gets here... hopefully this week, I can do a final mock up... take some pics.... then if everything fits good I can disassemble and send the frame off to the powder coater for some Kiwi green and clear coat 8-)
BigTerry
Post by BigTerry »
Thanks Mike :lol:
I finally got my Cerakote gear set up and decided to try some color.
So what better part to try it on then my back up 2 piece clutch cover... :o
As soon as it cooled off enough... I had to see....
Since I don't think we will have the Turbo Crank figured out for the 500 in time for this build to be completed, I'm building a new crank...
Getting the pre polish done..
I'm also double checking all the fittings and clearances...
This side is tight but has just enough clearance...
Final checking before disassembly and powder coating..
The rod is almost ready..
