kranker1450's 2000 kx250/k5 conversion
Re: kranker1450's 2000 kx250/k5 conversion
kranker1450
Thanks Blaster and Don. I have always used wd40 and a scotchbrite pad in the past with good results. Hopefully I will get a little farther on it this weekend. I had to indent the pipe a little more than i wanted to so it would "fit" like i wanted to. I spoke to a good friend about it and he assured me that i probably wouldn't even notice the difference in power and just laughed.
I got the frame off to powder coat. should have it back tomorrow. will start putting it all together. I will get some more pics for you then. Here is a pic of the wheels ready to be put on. Thanks for looking.
2000 kx250 TO k5 conversion 9-2.jpg (128.45 KiB) Viewed 3618 times
I got the Parts back from powder coat. Assembly has begun! I am pleased with the powdercoat, i think it turned out well. Here is a pic of the frame. Sitting on the table you can also see the dog bones,axle blocks and part of the triple trees. And yes the nasty hose on the on the side of the head will be replaced with a new blue silicon one. lol..Thanks!
2000 kx250 TO k5 conversion 9-3.jpg (110.87 KiB) Viewed 3618 times
I am slowly getting it put back together. here is the latest.
2000 kx250 TO k5 conversion 9-4.jpg (86.58 KiB) Viewed 3618 times
I do have a question for those that have done this conversion before. What did you do about the throttle cable routing out of the top of the carb? just heat and remold the tank? I thought I read something about a 125 carb top? here is a pick of what I am talking about.
2000 kx250 TO k5 conversion 9-5.jpg (75.49 KiB) Viewed 3618 times
Thanks again!
Here are the latest pics. slowly but I am getting there. The dog bones and the axle block are also powder coated to match the triples. Hard to see in the lighting.Thanks for looking.
2000 kx250 TO k5 conversion 9-6.jpg (100.26 KiB) Viewed 3616 times
2000 kx250 TO k5 conversion 9-7.jpg (107.72 KiB) Viewed 3616 times
Love the gold wheels!
