Vapor Vapour or Aqua Blasting, Is it worth the expense?
General discussion.
What's on your mind?
Re: Vapor Vapour or Aqua Blasting, Is it worth the expense?
Yesterday I was asked if I could fix the machine and send them a bill...
NEXT!!!
Started working on it today.
Fixed the leg..
Fixed the light housing..
Working on the wiring...
Should be able to test it some tomorrow.
Got her up and running...
Owwwwweeeee!!!
Ahhhhhh!!!!
kx500 head 100.png (1.37 MiB) Viewed 20573 times
Nissin Front brake calipers:
NISSIN FRONT BRAKE CALIPERS.JPG (110.47 KiB) Viewed 20588 times
NISSIN FRONT BRAKE CALIPERS 2.JPG (113.49 KiB) Viewed 20588 times
1992 KX250 HEAD BEFORE AND AFTER
92 KX250 HEAD VAPOR BLASTING OEM-CYCLE 3.JPG (74.11 KiB) Viewed 20526 times
92 KX250 HEAD VAPOR BLASTING OEM-CYCLE 4.JPG (58.91 KiB) Viewed 20526 times
KX250F engine just received today.
2010 kx250f vapor blaster oem-cycle 1.jpg (160.79 KiB) Viewed 20521 times
After a little love :D
2010 kx250f vapor blaster oem-cycle 2.jpg (242.58 KiB) Viewed 20521 times
INTAKE MANIFOLDS 100.JPG (85.31 KiB) Viewed 20438 times
INTAKE MANIFOLDS 102.JPG (98.6 KiB) Viewed 20438 times
INTAKE MANIFOLDS 103.JPG (74.52 KiB) Viewed 20438 times
INTAKE MANIFOLDS 101.JPG (101.63 KiB) Viewed 20438 times
INTAKE MANIFOLDS 104.JPG (60.97 KiB) Viewed 20437 times
INTAKE MANIFOLDS 105.JPG (47.7 KiB) Viewed 20437 times
