Page 2 of 4
Re: KX500 WR or overdrive transmission, is it possible?
Posted: Sun Oct 20, 2013 2:02 am
Wow!
That sounds great!
Are you going to offer your services when done? :D
Posted: Mon Oct 21, 2013 12:54 am
by 81cr450
Well failure #1 , kinda. It goes in all gears just a slight neutral 1st gear rub going on I'm sure it'll be obvious "where" the touch is going on when I open it back up. Rode for 30min or so drove it in every gear & did fine other than the little damn chatery box of rox sound :D & fifth would only engage or disengage clutchless ??? I was your gonna ruin it noises just you got issues so hopefully thats a plus
Arghhh I'm tiered & I gotta do it again :x
Posted: Mon Oct 21, 2013 2:01 am
I didn't know you were that close to trying something.
That's cool 8-)
If you ruined the gears or shafts let me know... I may have an extra set I'd be willing to donate to the cause. :D
Posted: Mon Oct 21, 2013 3:16 am
by 81cr450
Just sucks cause the bikes gotta come clear back down. I can see why fiddling with the trans hasnt been done more.
Thanks for the offer on the parts. I dont think I hurt a thing just marked them to see where the problem is :roll:
First should just be a shim adjustment or maybe a slight shave on a gear, fifth really has me boggled though where thats the complete opposite end of the trans. Hope its apparent.
Posted: Mon Oct 21, 2013 4:16 am
Yeah, that's quite the job assembling and disassembling and reassembling... :shock:
Keep us apprised as this could really help a lot of fellow KX riders... :ugeek:
Posted: Tue Oct 22, 2013 2:11 am
by 81cr450
Thinking about it today, I think I got it figured. I used hardened valve spring shims for the input shaft washer on the clutch arm side , they were bigger in OA diameter than the stock one so theyre rubbing on the 5th gear tooth tip , gotta be it. the other bit is just playing with hardened valve shims on the other side to get the depth right, thought I had it :oops: . feeling better about it today anyway. I know where the crucial measurement will be for replicating the process too, whether anyone will want to... Billet hub is gonna need to be part of this , stock has a steel insert in the center & narrowing that area to .475 just seems like an aftermarket hub might be better. Sorry if this is just random blather at this point , but it helps to think it through. I want to have it "working" by the first of Nov, so I can take it to vegas & let KXPegger ride it so I have a witness :lol:
As for pics I have a bunch & its basically what I commented on doing on ,that other site, but I need to get it right before I detail it. It would be nice to have you help with it Sandblaster as you do excellent presentation. Delete my nonsense as you see fit & all that
Posted: Tue Oct 22, 2013 3:08 am
I'll be happy to help any way I can.
If you want, send me the pics and I'll do the work up here and then transfer it over to kxriders. :D
You mentioned a billet hub?
Which hub would that be?
Posted: Tue Oct 22, 2013 11:20 pm
by 81cr450
Dur billet not the right word , just thinking after market without the insert, Im just a little nervous the insert might spin in the hub now
Posted: Tue Oct 29, 2013 3:01 am
by 81cr450
I did it. :mrgreen: No box of rocks sound, 5th is smooth. Ride tomorrow weather permitting . Raining right now & dark but initial run up & down the street. I gotta get the other computer up & sort pics. Woohoo
Posted: Tue Oct 29, 2013 3:22 am
That is great news!
Did you ever figure out what percentage of under drive you'll achieve with that gear box?
