Thinking about it today, I think I got it figured. I used hardened valve spring shims for the input shaft washer on the clutch arm side , they were bigger in OA diameter than the stock one so theyre rubbing on the 5th gear tooth tip , gotta be it. the other bit is just playing with hardened valve shims on the other side to get the depth right, thought I had it
. feeling better about it today anyway. I know where the crucial measurement will be for replicating the process too, whether anyone will want to... Billet hub is gonna need to be part of this , stock has a steel insert in the center & narrowing that area to .475 just seems like an aftermarket hub might be better. Sorry if this is just random blather at this point , but it helps to think it through. I want to have it "working" by the first of Nov, so I can take it to vegas & let KXPegger ride it so I have a witness
As for pics I have a bunch & its basically what I commented on doing on ,that other site, but I need to get it right before I detail it. It would be nice to have you help with it Sandblaster as you do excellent presentation. Delete my nonsense as you see fit & all that
