Customer jetting for a KX500
Re: Customer jetting for a KX500
1984 KX500
All stock with Short body Air Striker carb
Pilot 52
Main 160
Side 7
Air screw 2 turns
Needle NEEDLE-JET N89D 16009-1613
Clip 2nd from the top
Pete N.
1995 KX500
Elevation: Sea Level
Carb Long Body Air Striker (Not Chinese)
Pilot: 42
Main: 165
Clip in 2nd from top with the SUZUKI NECJ needle.
1.5 turns out on air screw.
High Port time, high compression engine
VP T2 fuel
sea level
38mm Air Striker Carb
Stic metering block
52 PILOT
190 MAIN
BLUE NEEDLE clip on the 2nd position
3 TURNS OUT ON THE SCREW
From Steve Paxton:
Mike here are my 1993 KX 500 settings.
My home altitude is 3500ft to 5000ft around Vegas, riding Desert washes and mountain single line.
I also race/ride upwards of 6500ft to 9000ft
In mid state locations.
I get excellent performance and mocha brown plug readings when up that high.
I have no problems at home with the same settings.
I installed a new 38mm air striker and had Sudco do initial jetting. At the same time I refreshed my top end with new NOS "A" piston, and sent that to Mellinium Technologies to match my "A" cylinder bore with new plating. Along with my knife / Grinding honing of all lead edges of intake locations at Reed cage and bottom of my cylinder. (My only mods to the engine) also replaced the Reeds.
I ultimately ended up going leaner one pilot size. After many settings trials.
The bike runs pump gas 97 octane,
Amsoil Interceptor oil at 50:1
I run a #9 plug
38mm Keihin Quad Vent Air Striker settings
for higher altitudes in Desert...
Here is where it runs, and performs at it's best, out pulling many 450f bikes. 😉
Main jet 160
Pilot jet. 55
Needle # 48-DGH (clip 2 from top)
Air Screw 2.25 turns
Colton Aeck #526 on the Hatch KX500 at Glen Helen Ca.
38mm Air Striker
Elevation: 1800-2000 ft
Temp 50-60F
Oil to Fuel ratio: 32:1
Fuel type: 50% VP C12 50% California Chevron 91 pump gas.
Needle: 16009-1613 or N89D 2nd clip from the top
Main: 168
Pilot: 58
Air screw: 1.5 turns out
Pipe: Pro Circuit PC2
