Prepping a set of KX500 engine cases for rebuilding
Bottom end tips and mods
Re: Prepping a set of KX500 engine cases for rebuilding
I just discovered some new information on raw aluminum.
I'm sure some of you probably know already but there may be others that can benefit from it.
When I scuffed up the surfaces in preparation for the JB-Weld I didn't put the JB-Weld on right away.
In fact, I cleaned them up with some carb cleaner and let them sit overnight.
The next morning I noticed that the aluminum was already a little darker and not as shiny as it was when I first cleaned it up.
So I did a little research and it turns out that the oxygen in the air will start causing the aluminum to oxidize almost immediately.
From what I found, within an hour a skin can develop which will inhibit the bonding of the JB-Weld to the aluminum.
It may not be much but why take the chance?
So I cleaned mine up again before applying the JB-Weld.
Here is how my cases looked after applying the JB-Weld.
kx500 engine case jb-weld 1.JPG (27.51 KiB) Viewed 14095 times
kx500 engine case jb-weld 2.JPG (21.35 KiB) Viewed 14095 times
Not the neatest job of applying the JB-Weld but I think it will work.
*** ATTENTION ***
11-1-17 I was given an update by John Braasch Kawasaki Team Green mechanic
"We used epoxy on both cases in those areas, then we went to using 1211 after the epoxy came loose and ran through the clutch and was stuck in between 2 clutch plates."
For those that don't know, THREE BOND 1211 Silicone Liquid Gasket 8-)
Thanks John
Another thing that may help you is the tools that I used to clean the cases up.
Besides the punch I used a wire wheel (Left).
However, I felt as though it may have left too smooth of a surface so I used a small cutting tool (Right).
Man, did that do a quick and nice job of cleaning.
Because of the radius shape it was easy to get into all the nooks and cranny's.
A word of caution.... This thing cuts QUICK!!!
kx500 engine case jb-weld 3.JPG (26.92 KiB) Viewed 14095 times
Had to fix the tower for the counter sprocket guard :(
So I got a piece of 1/2" round stock, drilled and taped it, also left it long.
Chamfered the angled end.
Ran a bolt through it to hold it all together.
Also, I ran a bottom tap all the way to the bottom of the tower hole as there was very few threads left.
tower fix.JPG (20.72 KiB) Viewed 14093 times
Then I took it next door and had my buddy weld it up for me.
tower fix -2.JPG (16.1 KiB) Viewed 14093 times
Once it was welded, I removed the bolt, ground the tower to the correct length, countersunk the end and cleaned up the edges.
I won't grind the weld down to clean it up because there is very little penetration and I don't want it to break off for no good reason.
Some guys drill and ream the main bearing oiling holes to .250".
I like to stay around .180" - .200" as the material is pretty thin there..
Since this was originally wrote, I invested in a vapor blaster and it was one of the best things I have done..
Now our cases are amazing 8-)
And no media impregnation...
KX GURU RACING 1992 KX500 SNOW BIKE ENGINE BUILD FOR BRENT 147.JPG (361.21 KiB) Viewed 12462 times
KX GURU RACING 1992 KX500 SNOW BIKE ENGINE BUILD FOR BRENT 148.JPG (353.02 KiB) Viewed 12462 times
There is also some other things that we could discuss such as the cylinder mating surfaces and the studs.
Again, thanks goes to Motorrad for his patience in tuning me up on many of the things you saw in this thread.
Markee757
Post by Markee757 »
I might have missed something, but what was the purpose in filling those 3 voids on the outside of the case halfs?
Sometimes the steel insert leaks all the way through the case so it's just a little extra insurance..
Return to “Bottom end”
