angular contact bearing
http://www.nationalprecision.com/librar ... 1-No1.html
- angular contact bearing.png (40.7 KiB) Viewed 13462 times
What does an Angular Contact Bearing offer a designer that a Radial Ball Bearing doesn’t?
The easy answer to that question is additional thrust load
capacity. So let’s take a look at how a thrust load affects a ball bearing. Here are images of a standard bearing (left image) and an angular contact bearing (right image).
The amount of thrust load a bearing can carry is directly
related to the contact angle, shown in the drawing. Standard miniature bearings, for example, generally have contact angles of 9-25 degrees, depending on the radial play. Angular contact bearings are available with contact angles from 15 to 40 degrees.This allows them to carry a much higher thrust load.
A radial ball bearing is designed to have the load primarily in a direction perpendicular to the axis of the bearing, that is, directly toward the center of the bearing. Depending on the radial play of the bearing, some thrust loading is possible.
Angular contact ball bearings also have raceways in the inner and outer rings that are displaced with respect to each other in the direction of the bearing axis. This allows them to reduce the compression loading on the balls while being loaded in the axial direction as well as in the radial direction.
