KX500 2 piece clutch cover adapter
I hear you.
I had that same pic and enlarged it a bit to show some more detail
kx500 2 piece clutch cover 1.JPG (50.84 KiB) Viewed 15528 times
Here is why the kx450f inner clutch cover won't work for the sliced bread method.
why the kx450f inner clutch cover will not work.JPG (58.91 KiB) Viewed 15528 times
Of course, if the kx250 clutch cover sliced bread method works, there is some after market covers ready to go for 92-08.
This is suppose to be a pic for 92-96 kx250
boyesen clutch cover.jpg (31.88 KiB) Viewed 15528 times
Just because the 450F's won't work for the sliced bread method doesn't mean we couldn't use a stock or after market cover like this one from Moose:
Looks like the 96 KX250 Inner clutch cover might be a bit on the large size :-)
96 kx250 inner clutch cover over the kx500 cover.JPG (92.62 KiB) Viewed 15527 times
I have a KX450F gasket coming to the shop tomorrow so we'll see what that leads to.
I got looking at the 450F Inner clutch cover again for doing the bread cutting method and it may yet still work.
I'll see how close the gasket is and go from there.
I need a small milling machine :-)
Post by Motorrad »
Sandblaster wrote:I have a KX450F gasket coming to the shop tomorrow so we'll see what that leads to.
The reason the Kx250 one is big.. is so there was room for your fingers while changing the clutch out....
perhapse this is why the one on destrys bike is from scratch..
Kx550 Power By
Post by Motorrad »
Friend of mine (local) just bought a small CNC mill.
want to talk about a dangerous combination with me and having access to that thing
Kx550 Power By
Do you have any programming skills?
I worked with some CAM programs years ago.
I can do some CAD still :-)
Post by Motorrad »
Sandblaster wrote:Do you have any programming skills?
hmm... lets see... degree from UCSD's Jacobs school of engineering in ... Mechanical engineering.
and worked for solar turbines for 3 years as a Cad/cam designer.. (till I realized I did NOT want to live my life in a cubicle, and quit....)
yea... I think I have worked with some
Kx550 Power By
Return to “Clutch”
