KX500 ELECTRICAL SPECS & WIRING DIAGRAM
A closer look at your electrical system
STATOR
83-85 KX500 - 21003-1109 -
336-504 OHMS BLACK/RED TO BLACK YELLOW
14.2-21.4 OHMS RED TO BLACK/YELLOW
10.4-15.6 OHMS WHITE/RED TO BLACK/YELLOW
(2 coil style) 86 KX500 - 21003-1141 -
432-648 OHMS BLACK/RED TO BLACK/YELLOW -
4.0-6.0 OHMS WHITE/GREEN TO WHITE/RED
(2 coil style) 87-89 KX500 - 21003-1169 -
432-648 OHMS: BLACK/WHITE TO BLACK/YELLOW -
4.0-6.0 OHMS: WHITE/RED TO BLACK/YELLOW
90-04 KX500 - 153-230 OHMS (Ricky Stator says you can run it up to 350 with no issues. I have also ran them out of spec with no issues as well) BLACK/WHITE TO BLACK/YELLOW -
7.9-11.9 OHMS: WHITE/RED TO BLACK/YELLOW
KX500 Spark Plug
1983-1984 KX500 REGULAR B9EG, V-TYPE (GOLD) B9EGV, IRIDIUM BR9EIX
1985-1997 KX500 REGULAR B8EG, V-TYPE (GOLD) B8EGV, IRIDIUM BR8EIX
1998-2004 KX500 REGULAR BR8EG, V-TYPE (GOLD) N/A, IRIDIUM BR8EIX WITH A SOLID TERMINAL NUT
The spark plug gap for the 1983-2004 KX500 is .024"
IGNITION COIL
Primary (Small wire)
83-86 KX500 .85-1.15 ohms
87 kx500 .8-1.2 ohms
88-89 kx500 .85-1.15 ohms
1990 and newer .26-.36 ohms
Secondary (Spark plug wire)
83-86 KX500 5.0-6.8K ohms
87 kx500 5.6-8.4K ohms
88-89 kx500 5.0-6.8K ohms
1990 and newer 2.6-3.6K ohms
Re: KX500 ELECTRICAL SPECS & WIRING DIAGRAM
83-85 KX500
83-85 KX500.jpg (459.29 KiB) Viewed 11951 times
1986 KX500
86 KX500.jpg (565.64 KiB) Viewed 11951 times
1987 KX500
1987 KX500.jpg (483.22 KiB) Viewed 11951 times
1988 KX125 KX250 KX500
88 KX125 KX250 KX500.jpg (522.12 KiB) Viewed 11950 times
1989 KX500
1989 KX500.jpg (415.29 KiB) Viewed 11950 times
1990-2004 KX500
90-04 KX500.jpg (374.04 KiB) Viewed 11950 times
ELECTRICAL SPECS KX500 1990-2004.png (546.89 KiB) Viewed 11948 times
Return to “Electrical”
