2004 KX500 Kick lever on your early model KX500
Bottom end tips and mods
You will need to use the Kick lever PN 13064-1201 which fits 98-04 KX500 (earlier ones will fit but use this one, it's better).
You will need the Kick lever shaft from 85-04 KX500 PN 13066-1056
And don't skimp out... get the bolt PN 92150-1800 and the washer PN 92022-1944.
04 kick shaft on 84 kx500.jpg (54.85 KiB) Viewed 10983 times
Return to “Bottom end”
