I have a couple clutch arm pullers (RELEASE-COMP-CLUTCH Part# 13102-1107) that are pretty worn out.
Discontinued part, does anybody have a way to repair these? Is there maybe one from a different bike that will work?
Thanks
Worn out clutch arm puller replacement/fix?
Re: Worn out clutch arm puller replacement/fix?
Wow! Those are bad...
Did you check eBay?
Did you check eBay?
Yeah I really don't know how they get that bad, I got both these engines 20th hand.
EBay's got nothing
I might be able to use one from a '99 KX250, general dimensions look similar. I checked and the needle bearings they both rotate on are the same so they've gotta be the same diameter
This is the discontinued part And here is a '99 KX250 arm In the picture it looks like the flat spot might be cut a little deeper on the 250 one
Even if it is cut a little deeper I may be able to just add a spacer to the opposite end of the clutch push rod to make up for that.
EBay's got nothing
Yeah, they are discontinued.
The shaft size on the 250 are the same.
I am not sure about the length of the arms.
