The engine was assembled with a .024" base gasket or .6mm.
We used the stock head and ran it.
Cylinder pressure was 175psi.
The results?
We lost 3 HP at the rear wheel
Where it improved is the over rev..
But, that was not unexpected...
Next we are going to start lowering the Port timing and see what happens.
If it reacts as the KX500 did then we should see some real improvements.
So stay tuned!!
- resize.jpg (659.59 KiB) Viewed 13124 times
