Well guys, Shift shafts are available, then they are discontinued, then they are available, then discontinued
One thing is for sure, it's just a matter of time before you won't be able to get them.
So, what can we do?
Of course there is always eBay but I'd like to do something a little better.
First, lets get some rough dimensions of the shaft...
The first dimension is the over all length of the shaft... 147.13mm
Remember, all dimensions are approximate at this point.
From the splined end of the shaft to the face of the plate.125.54mm
From the right side of the shaft to the inside of the plate is 21.64mm
