With all new bearings, bushings, shaft, and gear installation is fast an easy..
- KX GURU RACING GOVERNOR REBUILD 111.jpg (278.9 KiB) Viewed 13596 times
One other note...
I have 4 different governors to test.
The first is stock.
I have already Dyno'd it and know how it comes on and operated.
The second is a heavier spring than stock.
That will make the valve open slower and should provide a easier bottom end but it should hit harder on top.
The third uses two Tungsten Carbide bearings and two stock bearings.
They are installed across from one another to maintain a good balance.
Opening quicker than stock should make the bottom end hit harder.
Last I installed all Tungsten Carbide bearings which should make it open extremely fast.
Likely this will only be good for dunes, drag, or desert as the bottom end should be brutal.
Of course, we could lock the valves funny open
Once I have all the info I will post what I find..
