Kx500 TPS and power jet how to by Leo Sadzewicz
Re: Kx500 TPS and power jet how to by Leo Sadzewicz
Leo Sadzewicz: I’d like to mention the kx250 has 3D mapping which is one of the things that makes this mod SO sweet 😁
The power D just has one curve to my knowledge and cannot support a tps or a power jet.
That is the reason I didn’t buy the power D
Update from Leo Sadzewicz:
Timing needs to be here or even a little more advanced or top end will be a little flat
TPS STATOR SETTING.jpg (34.85 KiB) Viewed 13490 times
Update from Coby Hosford
One thing to add is make sure the plug that’s is being used is of the resistor type.
I went ahead and put on that and a resistor ceramic plug cap.
If not a person will experience some issues with the rpm switch stability due to rfi from the plug .
Leo Sadzewicz jetting info..
4000’
#9 slide
172
58
A N82N 3rd has best top end
A N89D 3rd slightly richer at full throttle.
#55 power jet is too rich.
40 works great but I haven’t tried a 42,45, or 48 yet. Just ordered them
B4himdude
Post by B4himdude »
Something that I noticed about the pwk38 airstriker I used is that I did not have to modify the carb when I did the conversion. I believe there may be 2 styles of the carb. A normal one and s shortbody version. All I needed to do was add a sleeve to the carb intake to the filter boot and clamp both on . There are probably several things that can be ised to do this but I a plumbing pipe reducer from the outer of the intake side of the carb to the inside of the boot. I think it was a 2&1/2” to a 2”. But it didn’t fit the carb perfect so I took a pipe the same of of the carb intake got it hot and melted the inside of the reducer to the same size on the inside and formed like a lip that the carb pressed into them clamped it and clamped the other side . So no modification on my carb for whatever reason...
Good info.
Yes, there is a short body and a standard body air striker.
Earlier versions are standard.
The newest version is a short body.
