Got the crank back :-)
KX GURU RACING KTX500E CRANKSHAFT 101.jpg (345.97 KiB) Viewed 11335 times
KX GURU RACING KTX500E CRANKSHAFT 102.jpg (340.71 KiB) Viewed 11335 times
Finally... A part that I can put on the bike and not have to worry about taking it off again :lol:
This is a Samco Husqvarna 2016 205 sxf T radiator hose.
I pulled the stock unit out to powder coat the frame and I just didn't trust the stock part after the abuse of getting it apart.
KX GURU RACING KTX500E SAMCO RADIATOR T HOSE 101.jpg (248.05 KiB) Viewed 11263 times
KX GURU RACING KTX500E SAMCO RADIATOR T HOSE 102.jpg (299.74 KiB) Viewed 11263 times
Ok... I had a real hard time getting some good shift forks.
I actually took a set to the Industrial Hard Chrome plater and had them built back up to stock specs.
Well... the guy didn't listen and he did not plate the pins on the forks... That's one of them main area's where the plating is mandatory...
Anyhow I drove over 4000 miles to buy out a collection of KX500 bikes and parts.
There was 12 sets of forks in the batch and only one set was close to new specs...
So.... I'm in the process of getting ready to build the bottom end...
Pics with be coming soon.
Next, the suspension is ordered and being set up for the average riding weight and ability of the Motorcross Action Magazine wrecking crew...
Oscar Cota is negotiating with some triple clamp guys to get some triple clamps and a GPR dampener.
Daryl at Motor Cross Action is negotiating with a few more benders to get some oversized rotor kits and some brake lines.
So stay tuned.. More fun filled action is headed your way :lol:
Hmmm... These might work...
Beautiful parts from Moto Master.
These should help slow the beast 8-)
MOTO MASTER BRAKE KtX500e KX GURU RACING BUILD 101.jpg (423.09 KiB) Viewed 11050 times
MOTO MASTER BRAKE KtX500e KX GURU RACING BUILD 102.jpg (613.63 KiB) Viewed 11050 times
MOTO MASTER BRAKE KtX500e KX GURU RACING BUILD 103.jpg (580.07 KiB) Viewed 11050 times
MOTO MASTER BRAKE KtX500e KX GURU RACING BUILD 104.jpg (600.17 KiB) Viewed 11050 times
MOTO MASTER BRAKE KtX500e KX GURU RACING BUILD 105.jpg (563.93 KiB) Viewed 11050 times
Thanks Moto Master!!!
I finally have my hands on the forks.... Now I need my triple trees, shock, and GPR dampener and I should be ready to go...
KX GURU RACING KTX500E BUILD OHLINS FORKS 101.jpg (407.31 KiB) Viewed 10996 times
Yes, you are seeing it right... These are used forks with some wear...
Oh well... That's what photoshop is suppose to be for :lol:
KX GURU RACING KTX500E BUILD OHLINS FORKS 102.jpg (173.88 KiB) Viewed 10996 times
Titanium axle
KX GURU RACING KTX500E BUILD TITANIUM AXLE 101.jpg (404.2 KiB) Viewed 10996 times
I finally got the KTM muffler pulled completely apart...
In case you don't know, I'm coring it for a KX500
KX GURU RACING FMF TITANIUM MUFFLER CONVERSION TO A KX500 101.jpg (78.79 KiB) Viewed 10986 times
KX GURU RACING FMF TITANIUM MUFFLER CONVERSION TO A KX500 102.jpg (518.05 KiB) Viewed 10986 times
KX GURU RACING FMF TITANIUM MUFFLER CONVERSION TO A KX500 103.jpg (358.78 KiB) Viewed 10986 times
KX GURU RACING FMF TITANIUM MUFFLER CONVERSION TO A KX500 104.jpg (288.24 KiB) Viewed 10986 times
KX GURU RACING FMF TITANIUM MUFFLER CONVERSION TO A KX500 105.jpg (310.01 KiB) Viewed 10986 times
I'm putting the races back in the frame.
I don't have any special tooling :(
But, I do have a old 2" trailer hitch ball that is a nice fit :lol:
KX GURU RACING TRIPLE BEARING RACE INSTALLATION 101.jpg (220.5 KiB) Viewed 10975 times
Good old ACME 8-)
KX GURU RACING TRIPLE BEARING RACE INSTALLATION 102.jpg (103.21 KiB) Viewed 10975 times
Ah... one other point.
I actually pushed in the races and then later decided that I should take some pics...
I put a rag between the bearing race and the ball before I started driving it in.
Also, look at the hammer I used, it is tiny... And I don't wack it... small taps drove the races in with no issues.
After I was done I inspected the bearing surface and there was no damage at all.
I have used this same procedure many times in the past with no issues.
It would have been better to put it into a press and use a socket or a slightly ground down race to press it ini.
But I knew I could do this and it was quick and easy 8-)
The top clamp is being replaced as soon as I get it.
I put this top clamp on to hold it together :lol:
Also, I'm replacing the bolts with Ti ;)
KX GURU RACING KTX500E BUILD.jpg (232.96 KiB) Viewed 10968 times
Mocking up the front end..
KX GURU RACING KTX500E 200.jpg (247.37 KiB) Viewed 10895 times
KX GURU RACING KTX500E 201.jpg (370.88 KiB) Viewed 10895 times
