KX500 KOYO TO NSK BEARING NUMBERS
Bottom end tips and mods
Ok... Recently some Koyo bearings were purchased that turned out to be bad even though they were brand new.
Motorrad gave me this interchange list of bearings from Koyo to SKF
I ordered all these and they all worked great.
so... here it is..
Ordered a bunch of parts today including all the snap rings for the transmission :-D
Tomorrow I am ordering all the bearings from Motorrads list:
Main bearings.
KIPS bearings
Water Pump
Clutch Pressure plate
Shift Drum bearing
Transmission LEFT CASE
Transmission RIGHT CASE
(special note on this bearing... A LOT of the ones out there now have a Plastic cage... Request a metal one, and CHECK IT before you leave
I Just don't trust plastic cages in transmissions....)
Return to “Bottom end”
