1987 kx500 engine - can not start
General discussion.
What's on your mind?
kyser777
Post by kyser777 »
HI
I tried to fire a 1987 engine kx500., can not! :oops:
when I tried to rev the engine with the kick, no spark however
when I rev the engine with a driller connected to the flywheel with some speed, sparks come out .
so it sounds impossible to make any sparks with my foot.
I put a new plug and new carb already jetted well for an other 2000 kx500
no fire at all!
what does it mean ??
by the way can I change the flywheel , stator , coil with a later model system?
I am ready to order parts, but I would like to make sure they will fit
thanks
Re: 1987 kx500 engine - can not start
As KX500's age this will be a greater and great issue.
Before you buy any parts, the first thing you need is a ohm meter.
You can get one at your local hardware or home improvement for under 20 dollars.
Then read this article:
http://www.oem-cycle.com/forum/viewtopi ... 112&t=1280
Test one piece at a time and this will tell you where your problem is.
You can swap out a newer year of KX500 electrical parts but you need to swap all the parts.
Or, you can buy a Power Dynamo system that replaces everything.
Alex Ward sells them.
60something
Post by 60something »
Just to be clear regarding what you said about having to swap ALL the parts when using newer parts on an '87, you are saying that a newer CDI module alone cannot be swapped in? I was looking at possible spare parts for my '87 and wondered if that would be possible. :?:
2006 Kawasaki KDX200 qty-2
1987 Kawasaki KX500
1991 Honda CB750 Nighthawk
Take a look here:
http://www.oem-cycle.com/KAWASAKIKX500BIKEID.shtml
Scroll way to the right...
Look up the coil, cdi, flywheel, and stator and check out the interchange info on all the parts.
I believe only the coil can be used across all the KX500 years.
I put this chart together a long time ago so I can't quite remember all the details :lol:
60something
Thanks Sandblaster. That was one of the first things I discovered on this site...really useful!! I was just thinking that some of those things are not quite directly interchangeable, but maybe a bolt hole may be different or wiring change etc... I have discovered a couple things at least that technically shouldn't interchange, but do (such as radiator louvers or screens). This is not at all to disparage your excellent interchange list!! When I get done with my bike, I'd like to post some pics showing some of those things to help some other poor soul who unwittingly adopted an '87. :lol:
1987 Kawasaki KX500
Oh yeah... If there is a color change there is a different part number.
I have some of that info on that chart.
If you have specific info that is not called out, let me know and I will update the chart.
Be careful on the electrical because I know that on the stators they had 2 coil systems a single coil systems.
Also the cdi's have different timing as well as different wire counts :shock:
