KX500 BOTTOM END REBUILD FOR SCOT By JT Engine Works & OEM-CYCLE
Re: KX500 BOTTOM END REBUILD FOR SCOT By JT Engine Works & OEM-CYCLE
Nice!
JT ENGINE WORKS AND OEM-CYCLE KX500 BOTTOM END REBUILD 123.JPG (73.21 KiB) Viewed 5916 times
Should be back together very soon...
JT ENGINE WORKS AND OEM-CYCLE KX500 BOTTOM END REBUILD 122.JPG (142.4 KiB) Viewed 5916 times
Getting real close...
JT ENGINE WORKS AND OEM-CYCLE KX500 BOTTOM END REBUILD 124.JPG (77.67 KiB) Viewed 5902 times
Twodeons
Post by Twodeons »
What’s up Jason my name is Deon I am new to the farm I’m building a banshee what a KX 500 motor I need your help it has a lot of vibration in the throttle I was wondering if you can help me out can you balance the crank Thanks
Jason can help you out.
Give him a ring at 541-653-5334
