How do you clean up your expansion chamber?
Here is a pic of a expansion chamber that is in really poor condition.
So, how do you get one like this clean?
Believe it or not I got this one to this point in about 30-45 seconds..
Just need one of these..
Here is what the flapper is
Re: How do you clean up your expansion chamber?
Here is another section of the pipe..
This took 15-20 seconds
Here is some other things you can do..
Tinfoil and Coke
SOS pads
Acid and scotchbrite (Muratic)
CLR Cleaner or wheel cleaner
blue, red, green, light grey scotchbrite
Naval jelly and scotchbrite
Soak in vinegar and scrub with scotchbrite
Toothpaste is the best cleaning agent you will find. Mix it 70/30 with autosol it's brilliant
CLR and scotchbrite
Dupont metal prep and scotchbrite
More methods
Sandblast it torch the welds and coat it in high temp clear.
Steel wire wheel , 3m scotchbrite pad and wd40 ... but there is a good way to prevent this bad rusty conditions.. spray it with wd40 or better put weapon-oil on it with a towel after every ride and clean.
Grassy Knoll: I have a suggestion.....there a toilet bowl cleaner called....The Works.....you squeeze it on, consistency of water and literally wash 90 % away as it runs off.... then dip a bristle brush in some, clean up last 10%....60 seconds done.... Then fistfull or 2 small bolts and cup or 2 of the works inside...shake the shit out of it.dump it out rinse it out with hose like brand new.....and around here they only sell that brand at dollar store so it's cheap.....My papa left my extra woods Gnarly pipe out of the shed all winter in snow etc......when I saw it it was unrecognizable ...... I was heated and he told me relax ..... He showed me toilet bowl cleaner. Spray it on and rust just runs off....... One of those old man secrets .. I Guess that cleaner has been around forever.... He said its how they kept farm tractor components rust free, car exhaust etc.... had it looking like day I got it
My pipes look good for years.
How?
I store inside where it is dry.
I'm not a rock hopper :shock:
When done riding, I wash my bike, dry the pipe, then wipe it down with wd-40.
Sure, it smokes a bit on start up but it's a smoker right? :lol:
This bike I had for 12 years before it was stolen...
That pipe was pristine..
2000 kx500 stolen 2 resize.jpg (596.16 KiB) Viewed 15569 times
Return to “Pipes Exhaust”
