On the knurling... great thinking...
I should have considered that as I worked in a machine shop for 15 years and designed many roller systems with knurling.
I even designed a double knurling head so you could knurl a cross hatch pattern all in one pass
But it was deemed to hard on the lathe for the type of knurling pattern they wanted
One product that you may want to consider in the future is Retaining Compound.
Retaining Compound and its Industrial Benefits
Loctite Retaining Compounds are anaerobic adhesives that can secure bearings, bushes and cylindrical parts into housings or onto shafts. They achieve maximum load transmission capability and uniform stress distribution, as well as eliminating fretting corrosion. Applied as a liquid, they form a 100 % contact between mating metal surfaces, eliminating the need for expensive replacement parts, time consuming machining or the use of mechanical methods. Loctite Retaining Compounds fill the inner space between components and cure to form a strong precision assembly.
- LoctiteKeyvisualretaining_605_169866_web_606W.jpg (46.34 KiB) Viewed 17213 times
This stuff is amazing... BUt it is murder getting it apart so know when to use it and how much
