Remember, the engine is trying to rotate with the Swingarm pivot pin being the centerline of the axis.
Something as demonstrated below.
Keeping the Head stay brackets in line with the greatest force is really important.
KX GURU RACING KTX500E BUILD 129.jpg (303.65 KiB) Viewed 10270 times
As you can see in this pic, there is plenty of room for pipe clearance.
KX GURU RACING KTX500E BUILD 130.jpg (375.79 KiB) Viewed 10270 times
Next, I'm checking carb clearance.
This is a 38mm Airstriker short bodied version.
I'm also testing a Standard body Airstriker as well as a Lektron.
KX GURU RACING KTX500E BUILD 132.jpg (416.53 KiB) Viewed 10269 times
KX GURU RACING KTX500E BUILD 133.jpg (340.06 KiB) Viewed 10269 times
KX GURU RACING KTX500E BUILD 134.jpg (385.59 KiB) Viewed 10269 times
KX GURU RACING KTX500E BUILD 135.jpg (376.9 KiB) Viewed 10269 times
As you can see, there is plenty of room :-)
I will also be running a reed spacer so that will improve the already ample clearance.
Oh yeah... Look what showed up from the Anodizer today 8-)
KX GURU RACING KTX500E BUILD ANNODIZE 101.jpg (414.06 KiB) Viewed 10248 times
Blasted all that nasty orange pumpkin rine right off the parts and then sent them to Scot Schneider.
He took them to his good buddy Kenny at Precision Anodizing in Oklahoma City.
Here is a link to his Facebook page
https://www.facebook.com/Precision-Anod ... 585119272/
I had him try and match the color of a cooler I already had.
As you can see the parts turned out great!
Thanks Scot and Kenny.
I really appreciate it!
Here is some other goodies I'm playing with for this build...
KX GURU RACING KX500 TURBO CRANK 101.jpg (262.17 KiB) Viewed 10231 times
KX GURU RACING KX500 TURBO CRANK 102.jpg (444.18 KiB) Viewed 10231 times
KX Guru Racing is testing this mod for Steve Parris at Parris Racing Concepts
His Facebook page is here:
https://www.facebook.com/steve.parris.399
Others have tried this mod before with varying degrees of success.
Dirt Bike magazine ran some tests on Steve's crank and they reported a nice increase in power on a smaller engine.
We are testing and tuning for a KX500 so it may or may not work.
I'm betting that it will, especially in view of the case mods that MUST be made to make this modification work.
Feeding my Titanium addiction :o
KX GURU RACING KTX500E BUILD 123.jpg (149.1 KiB) Viewed 10222 times
KX GURU RACING KTX500E BUILD 124.jpg (158.07 KiB) Viewed 10222 times
KX GURU RACING KTX500E BUILD 125.jpg (240.81 KiB) Viewed 10222 times
KX GURU RACING KTX500E BUILD 126.jpg (242.65 KiB) Viewed 10222 times
Wow... Using a Power Dynamo Ignition on this conversion will only require a new mounting bracket and a bit of trimming..
Easy money... 8-)
KX GURU RACING KTM KX500 CONVERSION 202.jpg (229.93 KiB) Viewed 10161 times
KX GURU RACING KTM KX500 CONVERSION 201.jpg (146.48 KiB) Viewed 10161 times
AND THE MOMENT YOU HAVE ALL BEEN WAITING FOR... :lol:
KX GURU RACING KX500 KTM CONVERSION ELECTRIC STARTER 102.jpg (461.63 KiB) Viewed 10152 times
KX GURU RACING KX500 KTM CONVERSION ELECTRIC STARTER 103.jpg (439.67 KiB) Viewed 10152 times
KX GURU RACING KX500 KTM CONVERSION ELECTRIC STARTER 104.jpg (413.89 KiB) Viewed 10152 times
Since I have to do something with the pipe color I decided to try a few colors out..
Gloss black???
KX GURU RACING 2016 KTM 250SXF KX500 CONVERSION 162.jpg (511.16 KiB) Viewed 10146 times
KX GURU RACING 2016 KTM 250SXF KX500 CONVERSION 163.jpg (492.22 KiB) Viewed 10146 times
I'm thinking NO WAY!!!!! :o :shock: :lol:
Ben Brown had his pipe nickle plated..
Als Plating in Ft. Worth Tx, did it in 1 day $85
It certainly an option...
nickle plating.jpg (83.3 KiB) Viewed 10228 times
