When you are installing a engine after a rebuild there is so much that needs to be done..
- JT ENGINE WORKS KX GURU RACING ENGINE BUILD FOR JEFFS 93 125.jpg (532.42 KiB) Viewed 8799 times
Thoroughly clean the carb.
Install a new throttle cable.
Completely disassemble, clean, and re-seal the air box boot, and so much more.
Then you find all the small things the bike needed.
In this case, exhaust mounts, muffler seal, and several misc doodads..
- JT ENGINE WORKS KX GURU RACING ENGINE BUILD FOR JEFFS 93 126.jpg (482.49 KiB) Viewed 8799 times
- JT ENGINE WORKS KX GURU RACING ENGINE BUILD FOR JEFFS 93 127.jpg (442.46 KiB) Viewed 8799 times
