Sean Collier's "The Beast" Engine in for a refresh and mods.
See what's up in Sean's world
As some will remember we had this engine in about 9 months ago.
We were told under no uncertain terms not to improve the performance.
So here was what we were told.
Make it shift good, and try to make it survive for a while longer.
The plating on the cylinder was worn out around the exhaust port, the piston was junk, and all the shift components were extremely worn out.
So, we replaced all the worn out parts with used parts that were still in factory spec.
We cleaned everything, polished a few parts, replaced all the bearings, seals, gaskets, o-rings, snap rings, and even tossed in a used piston with new rings.
After it was done the engine ran very well but it still had worn plating that desperately need to be replaced.
The crank was pretty worn as well..
Also, the power on this engine was explosive which makes it difficult to ride for 30+ minutes against other pro riders :shock:
Oscar put an hour meter on the bike the first time we had it.
When we got it back it had 10.8 more race hours on it.
Frankly I'm shocked it held together :lol:
Our goal this time is to rebuild the cylinder and head to the same specs as the engine in Groot.
New plating, porting, piston and crank are all in the works, along with some special mods that we will get too later 8-)
Re: Sean Collier's "The Beast" Engine in for a refresh and mods.
I received the engine today..
Sean Collier The Beast engine rebuild 101.jpg (416.17 KiB) Viewed 23384 times
It just needs a minor tune up :lol:
On the pressure washing mat.
Sean Collier The Beast engine rebuild 102.jpg (315.31 KiB) Viewed 23384 times
Ready to crack here open...
Sean Collier The Beast engine rebuild 105.jpg (321.46 KiB) Viewed 23383 times
I love when a polished part looks like this nearly a year of racing later..
Sean Collier The Beast engine rebuild 103.jpg (361.58 KiB) Viewed 23383 times
The bad thing is... the exhaust port is not looking any better...
Sean Collier The Beast engine rebuild 104.jpg (233.35 KiB) Viewed 23382 times
Here is a vid showing the play in the piston..
https://www.youtube.com/watch?v=VUTfanjjw08
I already know the port timing so I don't have to worry about that.
But I still need to get the head squish calculated so I need to get some additional measurements..
Sean Collier The Beast engine rebuild 106.jpg (396.66 KiB) Viewed 23380 times
More to come... :o
I started doing the rough porting on the cylinder today..
As you can see, this thing was ready to blow :shock:
KX GURU RACING MODIFIED KX450F REAR BRAKE CALIPER 114.jpg (212.3 KiB) Viewed 23304 times
KX GURU RACING MODIFIED KX450F REAR BRAKE CALIPER 115.jpg (230.58 KiB) Viewed 23304 times
KX GURU RACING MODIFIED KX450F REAR BRAKE CALIPER 116.jpg (349.52 KiB) Viewed 23304 times
KX GURU RACING MODIFIED KX450F REAR BRAKE CALIPER 117.jpg (147.37 KiB) Viewed 23304 times
We are going to toss the stock carb and use a 97 KX250 carb 8-)
before
KX GURU RACING MODIFIED KX450F REAR BRAKE CALIPER 118.jpg (335.57 KiB) Viewed 23303 times
After
KX GURU RACING MODIFIED KX450F REAR BRAKE CALIPER 119.jpg (306.25 KiB) Viewed 23303 times
I spent a bit of time doing the rough porting the other day..
Today, Jason put his hand to the port tools and began to massage the cylinder..
No gloves, no eye protection... Nice Jason... Nice...
KX GURU RACING rebuilding the beast 120.jpg (412.5 KiB) Viewed 23288 times
Jason has a bit more roughing is done..
KX GURU RACING rebuilding the beast 121.jpg (254.96 KiB) Viewed 23273 times
shue415
Post by shue415 »
Hey
Why hasnt sean been racing the kx 500?
I see at mammoth he raced a KTM
