Jason's Quality Engine Builds
Plating is hashed..
KX GURU RACING 1992 KX500 SNOW BIKE ENGINE BUILD FOR BRENT 121.JPG (83.9 KiB) Viewed 34505 times
Exhaust Port work is rough..
KX GURU RACING 1992 KX500 SNOW BIKE ENGINE BUILD FOR BRENT 122.JPG (74.67 KiB) Viewed 34505 times
Clutch cover is jacked up..
KX GURU RACING 1992 KX500 SNOW BIKE ENGINE BUILD FOR BRENT 123.JPG (132.26 KiB) Viewed 34504 times
Oh, good ole JB Weld... Someone knew they had an issue.. :lol:
KX GURU RACING 1992 KX500 SNOW BIKE ENGINE BUILD FOR BRENT 124.JPG (106.74 KiB) Viewed 34504 times
I'd like to build one KX500 that did not need a new sprocket guard tower... :shock:
KX GURU RACING 1992 KX500 SNOW BIKE ENGINE BUILD FOR BRENT 125.JPG (169.51 KiB) Viewed 34503 times
Cases are in sad shape,,
KX GURU RACING 1992 KX500 SNOW BIKE ENGINE BUILD FOR BRENT 126.JPG (150.69 KiB) Viewed 34503 times
But no worries... After Jason and I get done with them.... You won't recognize them...
Here is what the left case looks like just before I sent it off to weld..
KX GURU RACING 1992 KX500 SNOW BIKE ENGINE BUILD FOR BRENT 127.JPG (111 KiB) Viewed 34502 times
This is what we call our Pre-clean up..
Gotta make sure the welder has nice clean material to work with..
Wossner rod after polishing..
KX GURU RACING 1992 KX500 SNOW BIKE ENGINE BUILD FOR BRENT 131.JPG (55.24 KiB) Viewed 34501 times
KX GURU RACING 1992 KX500 SNOW BIKE ENGINE BUILD FOR BRENT 128.JPG (76.19 KiB) Viewed 34501 times
KX GURU RACING 1992 KX500 SNOW BIKE ENGINE BUILD FOR BRENT 129.JPG (57.08 KiB) Viewed 34501 times
KX GURU RACING 1992 KX500 SNOW BIKE ENGINE BUILD FOR BRENT 130.JPG (59.93 KiB) Viewed 34501 times
I like eye candy 8-)
The top rack has the parts for this project.
All these are in their pre-cleaning stage..
KX GURU RACING 1992 KX500 SNOW BIKE ENGINE BUILD FOR BRENT 132.JPG (117.13 KiB) Viewed 34500 times
Kx500fan
Post by Kx500fan »
Do you build a snobike engine different then a dirt bike engine?
Hartmanbw
Post by Hartmanbw »
It's all about the power man, something tells me this bike would be scary on the dirt!
Welcome to the forum Hartmanb :D
You are so right...
Actually it would make a great desert or dunes motor but for a dirt bike it would be a wild child.
Yet, some of the mods we are going to do to it will also give it some decent low end power.
The fact is, I should go down to the garage and do some of the cylinder mods tonight... But I'm too lazy.. :lol:
I went ahead and spent some time last night porting the cylinder.
Normally the exhaust ports look like this..
KX GURU RACING 1992 KX500 SNOW BIKE ENGINE BUILD FOR BRENT 133.JPG (90.38 KiB) Viewed 34463 times
But not for long... Just starting to whittle away some material..
KX GURU RACING 1992 KX500 SNOW BIKE ENGINE BUILD FOR BRENT 134.JPG (78.43 KiB) Viewed 34463 times
Return to “JT Engine works builds”
