1993 KX500 Engine build for Jeff Y
Re: 1993 KX500 Engine build for Jeff Y
We finally received a Wossner rod :o
I couldn't get the one's I ordered from Wossner as they are on back order (Forever), but I did find one in the UK.
It only cost me double what it should have but you gotta do what you gotta do.
I want this engine D.O.N.E...
JT ENGINE WORKS KX GURU RACING ENGINE BUILD FOR JEFFS 93 116.jpg (391.15 KiB) Viewed 8870 times
But that's not good enough...
JT ENGINE WORKS KX GURU RACING ENGINE BUILD FOR JEFFS 93 117.jpg (583.54 KiB) Viewed 8870 times
That's better...
We should have the cylinder back from Millennium late this week :shock: Finally... :?
So Jason is tying up a few loose ends before the cylinder comes in..
Here Jason is cleaning up the chain wear around the transmission output shaft.
JT ENGINE WORKS KX GURU RACING ENGINE BUILD FOR JEFFS 93 118.jpg (470.05 KiB) Viewed 8839 times
Delay delays delays delays... But finally.... Finally making some progress..
JT ENGINE WORKS KX GURU RACING ENGINE BUILD FOR JEFFS 93 119-1.jpg (356.8 KiB) Viewed 8821 times
I love the color of this cover...
JT ENGINE WORKS KX GURU RACING ENGINE BUILD FOR JEFFS 93 119-2.jpg (211.28 KiB) Viewed 8821 times
It's gonna run good and look great!
JT ENGINE WORKS KX GURU RACING ENGINE BUILD FOR JEFFS 93 120.jpg (276.7 KiB) Viewed 8820 times
JT ENGINE WORKS KX GURU RACING ENGINE BUILD FOR JEFFS 93 121.jpg (325.29 KiB) Viewed 8820 times
JT ENGINE WORKS KX GURU RACING ENGINE BUILD FOR JEFFS 93 122.jpg (255.75 KiB) Viewed 8819 times
Now for the good part...
JT ENGINE WORKS KX GURU RACING ENGINE BUILD FOR JEFFS 93 123.jpg (660.5 KiB) Viewed 8819 times
You put all the blood, sweat, and tears, into building a awesome engine.
Why not spend a few minutes (Ok, maybe a little longer) cleaning out the carb?
JT ENGINE WORKS KX GURU RACING ENGINE BUILD FOR JEFFS 93 124.jpg (440.51 KiB) Viewed 8817 times
When you are installing a engine after a rebuild there is so much that needs to be done..
JT ENGINE WORKS KX GURU RACING ENGINE BUILD FOR JEFFS 93 125.jpg (532.42 KiB) Viewed 8809 times
Thoroughly clean the carb.
Install a new throttle cable.
Completely disassemble, clean, and re-seal the air box boot, and so much more.
Then you find all the small things the bike needed.
In this case, exhaust mounts, muffler seal, and several misc doodads..
JT ENGINE WORKS KX GURU RACING ENGINE BUILD FOR JEFFS 93 126.jpg (482.49 KiB) Viewed 8809 times
JT ENGINE WORKS KX GURU RACING ENGINE BUILD FOR JEFFS 93 127.jpg (442.46 KiB) Viewed 8809 times
JT ENGINE WORKS KX GURU RACING ENGINE BUILD FOR JEFFS 93 128.jpg (432.09 KiB) Viewed 8808 times
JT ENGINE WORKS KX GURU RACING ENGINE BUILD FOR JEFFS 93 129.jpg (509.21 KiB) Viewed 8808 times
JT ENGINE WORKS KX GURU RACING ENGINE BUILD FOR JEFFS 93 130.jpg (491.86 KiB) Viewed 8808 times
JT ENGINE WORKS KX GURU RACING ENGINE BUILD FOR JEFFS 93 131.jpg (518.44 KiB) Viewed 8808 times
New engine... First kick start up...
https://www.youtube.com/watch?v=CdxsGnkWbYY
Another nice job..
A little of this and that..
JT ENGINE WORKS KX GURU RACING ENGINE BUILD FOR JEFFS 93 132.jpg (603.63 KiB) Viewed 8799 times
JT ENGINE WORKS KX GURU RACING ENGINE BUILD FOR JEFFS 93 133.jpg (160.81 KiB) Viewed 8799 times
Love this stuff..
JT ENGINE WORKS KX GURU RACING ENGINE BUILD FOR JEFFS 93 135.jpg (139.55 KiB) Viewed 8798 times
