2K K5 getting old but not long in tooth :-)
2000 kx500.jpg (271.22 KiB) Viewed 16065 times
coquinati
Re: 2K K5 getting old but not long in tooth :-)
Post by coquinati »
wow=)beautiful motocross=)is kx 500?=)year?=)you drive in sand?beach? :D the tyres are sand :D
Friar-Tuck
Post by Friar-Tuck »
Long live the King! :lol:
It's amazing that a bike that changed so little since 1989 is still so revered and in some cases so relevant.
Hail to the king :D
Frank The Tank
Post by Frank The Tank »
That bike looks FAST!!!
I like wher you almost hit that guy on the quad :o
Bettin you had to change your chonies :shock:
Yeah it was close.
He kept telling me how fast his quad was so I let him go first.
I can't turn quite as fast as he could on his quad on the side of the hill.
I probably could if I practiced doing it a bit.
Then coming down you could see where I hit third gear........
I almost took us both out :o
Make for good viewing.
I had to burn those chonies :D
Tardboy
Post by Tardboy »
Burning chonies?
I don't like the smell of it :shock:
Time for a little maintenance...
I pulled the seat off discovered that I still have a K&N in there.
In all honesty I hate they way they fit, I hate the reduced area for the dirt to stick to and I never feel as though I'm getting it on there right.
k and n filter.PNG (459.03 KiB) Viewed 15920 times
So, out it comes and in goes a new one....
Good thing I had the original cage in my private reserve junk pile...
But, before I put in the cage and filter, in goes a PC Racing Pro-Seal Air filter gasket.
I just love the way these things work, clean the mating surface with some acetone and stick it on.
pc racing pro seal.PNG (349.71 KiB) Viewed 15920 times
Next, put the stock cage on and the No Toil dual stage air filter.
They even give you some plastic gloves so you don't get you hands sticky :-)
no toil filter.PNG (714.49 KiB) Viewed 15920 times
Put the bolt in and your done.
all ready.PNG (504.92 KiB) Viewed 15920 times
No grease needed and it fits superbly.
I gotta say I like this combo ...
You know, for as clean as this engine is, I wonder how bad my studs are :o
clean engine.PNG (745.78 KiB) Viewed 15919 times
Return to “What do you ride?”
