Ok, so your all ready to install your new set up right?
Not so fast Jack.....
You still need to set the Tension on the reed pedals.
How is this done?
Look carefully at the reed clamp.
Note that they are slotted.
- V FORCE 2 REED VALVE INSTALLATION -9-6.PNG (313.79 KiB) Viewed 19407 times
According to Moto Tassinari the Low tension setting is for low to mid range power and the hi tension setting is for High end power.
Here is a pic demonstrating the high tension vs. low tension settings.
However, after dyno testing stock and modified engines, then running the results on the streets I have found that nothing beats all around torque and HP when the petals are set in the low tension setting. That's what I run on all my bikes period.
Will the petals wear out quicker? I'm sure they will but I've never replaced mine
- V FORCE 2 REED VALVE INSTALLATION -5.PNG (726.46 KiB) Viewed 19407 times
Note that there is a .004" gap when you set the reed clamp closest the carburetor making it harder to open the reed pedals.
When you set the reed clamp further from the carburetor there is a .050" gap allowing the reed pedals to open easier.
So just for the record:
Reed clamp closer to the carburetor = High tension setting
Reed clamp farther from the carburetor = Low tension setting
This is my story and I'm sticking to it for now
