SS front brake line
Divenride
SS front brake line
Post by Divenride »
Has anyone installed a Stainless Steel brake line on the front? If so what brand?
Galfer offers one but it incorporates a hard 90 degree fitting that goes around the outside of the caliper and leaves it exposed to a crash on the left side. I've talked to them and they suggested routing it similar to a modern bike ( inside the fork leg) which opens another can of worms regarding mounting the cable to the fork leg protector.
Re: SS front brake line
The cool way would be to replace your forks with some KX450F forks and buy a KX450F front hose and route it like what's on Sean Colliers..
Sean Colliers KX Guru Racing KX500 build 101.JPG (133.63 KiB) Viewed 8604 times
Then again... It would not be the cheap route :shock:
Sean Colliers KX Guru Racing KX500 build 102.JPG (162.52 KiB) Viewed 8603 times
Sean Colliers KX Guru Racing KX500 build 103.JPG (84.52 KiB) Viewed 8602 times
Return to “Brakes”
