Look close..
You can see the carb down there..
KX GURU RACING 2016 KTM 250SXF KX500 CONVERSION 169.jpg (252.63 KiB) Viewed 10927 times
Oh yeah... That's one big issue solved and it was really easy...
KX GURU RACING 2016 KTM 250SXF KX500 CONVERSION 170.jpg (543.97 KiB) Viewed 10925 times
With that done we turned our attention to the motor mounts..
We are re-using the old mounts.
It will have that factory look :lol:
KX GURU RACING 2016 KTM 250SXF KX500 CONVERSION 171.jpg (415.01 KiB) Viewed 10925 times
Here is another shot of the air box looking down at the carb...
Oh yeah, I like it..
KX GURU RACING 2016 KTM 250SXF KX500 CONVERSION 172.jpg (293.24 KiB) Viewed 10925 times
Here's Jan's bike..
Jans KTM.jpg (46.3 KiB) Viewed 10920 times
Jan also suggested using a KTM 300 2 stroke air box with a 1986 KX500 boot..
He believes it gives a better angle from the box to the carb..
1986 boot.jpg (150.54 KiB) Viewed 10918 times
What could be better then a modern chassis waiting for a 2T transplant?
That's right.... Two modern chassis waiting for a 2T transplant :o
KX GURU RACING 2016 KTM 250SXF KX500 CONVERSION 175.jpg (540.75 KiB) Viewed 10888 times
KX GURU RACING 2016 KTM 250SXF KX500 CONVERSION 173.jpg (571.47 KiB) Viewed 10888 times
KX GURU RACING 2016 KTM 250SXF KX500 CONVERSION 174.jpg (561.35 KiB) Viewed 10888 times
Just about have it all crated up and sending it to my buddy Adam up in the great land of Canadia :lol:
Since Adam's will get a Honda motor I figured I'd wrap the crate up in some appropriate wallpaper..
I started working on the head stays today.
I made a little bit of progress..
KX GURU RACING 2016 KTM 250SXF KX500 CONVERSION 176.jpg (357.41 KiB) Viewed 10883 times
KX GURU RACING 2016 KTM 250SXF KX500 CONVERSION 177.jpg (135.12 KiB) Viewed 10883 times
KX GURU RACING 2016 KTM 250SXF KX500 CONVERSION 178.jpg (132.62 KiB) Viewed 10883 times
KX GURU RACING 2016 KTM 250SXF KX500 CONVERSION 179.jpg (255.31 KiB) Viewed 10883 times
KX GURU RACING 2016 KTM 250SXF KX500 CONVERSION 180.jpg (217.11 KiB) Viewed 10883 times
Ok, Adam's bike is on it's way...
I've been working on getting the caliper prepped for the anodizer.
The better the polish the better the finish..
As you can see I have a ways to go..
I'm looking to change the color scheme to something more Kawi and less pumpkin.
This is a bad pic, and I don't have photoshop... But if you have some patience you can get some rough ideas...
KX GURU RACING 2016 KTM 250SXF KX500 CONVERSION 181.jpg (486.51 KiB) Viewed 10841 times
It's a picture of a picture but... whatever..
