1989 CR250R HONDA ENGINE BUILD
Jason's Quality Engine Builds
Check it out... Nice...
JT ENGINE WORKS 1989 CR250R HONDA ENGINE BUILD 103.jpg (186.95 KiB) Viewed 15209 times
JT ENGINE WORKS 1989 CR250R HONDA ENGINE BUILD 102.jpg (186.4 KiB) Viewed 15209 times
JT ENGINE WORKS 1989 CR250R HONDA ENGINE BUILD 101.jpg (186.19 KiB) Viewed 15209 times
Re: 1989 CR250R HONDA ENGINE BUILD
JT ENGINE WORKS 1989 CR250R HONDA ENGINE BUILD 104.jpg (231.35 KiB) Viewed 15208 times
Ok... You have seen what Jason has done so far.. Now let's see what he started with..
JT ENGINE WORKS 1989 CR250R HONDA ENGINE BUILD 105.jpg (83.99 KiB) Viewed 15208 times
Remind me not to eat dinner at Jason's house...
JT ENGINE WORKS 1989 CR250R HONDA ENGINE BUILD 106.jpg (216.15 KiB) Viewed 15208 times
JT ENGINE WORKS 1989 CR250R HONDA ENGINE BUILD 109.jpg (163.57 KiB) Viewed 15207 times
JT ENGINE WORKS 1989 CR250R HONDA ENGINE BUILD 108.jpg (103.51 KiB) Viewed 15207 times
JT ENGINE WORKS 1989 CR250R HONDA ENGINE BUILD 107.jpg (331.84 KiB) Viewed 15207 times
JT ENGINE WORKS 1989 CR250R HONDA ENGINE BUILD 110.jpg (163.71 KiB) Viewed 15206 times
JT ENGINE WORKS 1989 CR250R HONDA ENGINE BUILD 111.jpg (232.58 KiB) Viewed 15206 times
JT ENGINE WORKS 1989 CR250R HONDA ENGINE BUILD 112.jpg (188.03 KiB) Viewed 15206 times
JT ENGINE WORKS 1989 CR250R HONDA ENGINE BUILD 113.jpg (239.5 KiB) Viewed 15205 times
JT ENGINE WORKS 1989 CR250R HONDA ENGINE BUILD 114.jpg (153.79 KiB) Viewed 15205 times
JT ENGINE WORKS 1989 CR250R HONDA ENGINE BUILD 115.jpg (162.48 KiB) Viewed 15205 times
JT ENGINE WORKS 1989 CR250R HONDA ENGINE BUILD 116.jpg (121.13 KiB) Viewed 15204 times
JT ENGINE WORKS 1989 CR250R HONDA ENGINE BUILD 117.jpg (224.23 KiB) Viewed 15204 times
JT ENGINE WORKS 1989 CR250R HONDA ENGINE BUILD 118.jpg (188.73 KiB) Viewed 15204 times
It looked great in the box when it got here :-)
JT ENGINE WORKS 1989 CR250R HONDA ENGINE BUILD 119.jpg (159.36 KiB) Viewed 15203 times
Vid of the valves working just like they should
https://youtu.be/JlhvzcW5P-o
JT ENGINE WORKS KX GURU RACING 1989 CR250R ENGINE BUILD 101.jpg (297.36 KiB) Viewed 15143 times
JT ENGINE WORKS KX GURU RACING 1989 CR250R ENGINE BUILD 102.jpg (258.46 KiB) Viewed 15143 times
JT ENGINE WORKS KX GURU RACING 1989 CR250R ENGINE BUILD 103.jpg (344.75 KiB) Viewed 15141 times
JT ENGINE WORKS KX GURU RACING 1989 CR250R ENGINE BUILD 104.jpg (338.01 KiB) Viewed 15141 times
JT ENGINE WORKS KX GURU RACING 1989 CR250R ENGINE BUILD 105.jpg (277.49 KiB) Viewed 15140 times
JT ENGINE WORKS KX GURU RACING 1989 CR250R ENGINE BUILD 106.jpg (374.02 KiB) Viewed 15140 times
Return to “JT Engine works builds”
